Author Topic: 2nd hard drive Infinity X  (Read 288 times)
the-bossTopic starter
« on: 24-August-18, 09:56:53 »
Hello, I have an MSI Infinity X bought, there is 1 hard drive and I would like to build a 2nd, there is room for it. However, there is no extra sata plug available. Can I buy a special extension plug for this. Or do you know another solution
Yang
  • AIO Moderator
Re: 2nd hard drive Infinity X
« Reply #1 on: 27-August-18, 00:39:37 »
Please provide some information as below to us for this system you used:
1. Serial number on the back cover and on the box.
It is SOP how to check it as below link:
http://www.msi.com/page/warranty
2. The number:9S6-xxxx-xxx that you can find it on the box.
3.What kind of storage is you want to add?
It is specification for Infinite X on MSI website.
2 x M.2 SSD (Auto Switch, Intel Optane support)
 1 x 2.5" SSD / HDD
 2 x 3.5" HDD
https://www.msi.com/Desktop/Infinite-X/Specification
