Author Topic: Do I need a spare cpu to update bios on MSI b350 mortar mATX board?  (Read 679 times)
joshuamathesjmTopic starter
Hello, this is my first pc build and I decided to purchase a MSI B350 mortar MATX motherboard to go with my cpu. The cpu I purchased is a AMD RYZEN 5 2600. From my research I believe that the motherboard does support the cpu but only with a BIOS update and I will be updating the bios from a usb drive. My question is can I update the bios with the new cpu installed or do I have to get another cpu in order to update the bios? And if so, which cpu can I use? Thanks.
  • 微星科技
If the mainboard does not already come with a Ryzen 2000 compatible bios you need a supported cpu to flash the bios. Alternatively you can contact a pc-shop to flash it for you.
https://support.amd.com/en-us/kb-articles/Pages/2Gen-Ryzen-AM4-System-Bootup.aspx
AMD Ryzen 9 3900X
Windows 10 Pro
