Author Topic: UPDATE CPU from i3 2100 to i5 3470  (Read 222 times)
apostolopoulos_vasilisTopic starter
« on: 11-October-18, 09:02:04 »
Hello guys! i have updated my CPU from i3 2100 to i5 3470 to motherboard PH67A-C43 (MS-7673). i have reseted the drivers but  it keeps restarting. my first thougt was to update the bios but when i install them through the windows
it restarts and gets me back to the windows with nothing fixed. is there any changes that i have to do in bios so that the setup can be done properly?????
  • 微星科技
Re: UPDATE CPU from i3 2100 to i5 3470
« Reply #1 on: 11-October-18, 10:46:16 »
Well, what actual bios version do you have?
Windows 10 Pro
MSI MAG BUNKER Case
