Author Topic: RAM compatibility issue  (Read 302 times)
kitoyskiTopic starter
« on: 12-October-18, 19:09:38 »
my newly built pc Ryzen 2200G / MSI A320M PRO VH Plus, / DDR 4 Team Elite 2400mhz tpD48G2400HC16BK
its always crashing?BSODs. i found out that the ram model is not on the supported list. is there any solution aside from changing the ram model? am not really a techie guy, i hope you can share some of your thoughts.  thanks
darkhawk
Re: RAM compatibility issue
« Reply #1 on: 12-October-18, 19:42:43 »
changing the color and font of the text makes it very difficult to read on other themes. Particularly the old original MSI theme, where the background is white.
That being said....just because your RAM isn't on the supported list doesn't mean it's incompatible.
What are the crashes/BSoD's saying? Have you checked your system logs to see what the errors are? (control panel -> administrative tools -> event viewer)
System 3MSI Z390 GodlikeIntel i9 9900K32GB DDR4 @ 3600 MHz MSI RTX 2070 Gaming Z 8GB
