Author Topic: msi gaming gtx 1060 latest bios?  (Read 449 times)
cypher_69_Topic starter
« on: 15-October-18, 10:04:09 »
hi I got the msi gtx 1060 gaming card GP106 PG410 SKU 30 VGA BIOS MSINV328MH.131 bios version 86.06.0E.00.35 and its from 2016-07-01 in gpu-z is this the best one yet ? thanks.
  • 微星科技
Re: msi gaming gtx 1060 latest bios?
« Reply #1 on: 15-October-18, 12:27:44 »
Add your S/N
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #2 on: 15-October-18, 14:19:29 »
PCI Device 10DE-1C03 / 1462-3282  (Rev A1) this is the serial?
  • 微星科技
« Reply #3 on: 15-October-18, 14:23:43 »
No, it looks like this:
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #4 on: 15-October-18, 14:27:34 »
s/n 602-V328-13SB1607000204
  • 微星科技
« Reply #5 on: 15-October-18, 14:34:57 »
As you are using version NV328MH.131 there is an update. Latest is NV328MH.133: https://forum-en.msi.com/index.php?topic=296954.msg1673622#msg1673622
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #6 on: 15-October-18, 14:46:24 »
cool thanks a lot.
  • 微星科技
« Reply #7 on: 16-October-18, 10:31:41 »
:hat tip:
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #8 on: 09-January-19, 09:36:16 »
Any new bios update for my card? as maybe I will sell to get rtx 2070... good choice or?
  • 微星科技
« Reply #9 on: 09-January-19, 11:05:47 »
No, NV328MH.133 is still the latest. Don't expect any further update. This should be the final one.
RTX 2070 is roughly on GTX 1080 level so of course an upgrade. If you can get a good deal for the old one do it.
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #10 on: 09-January-19, 13:47:32 »
okay thanks yes someone maybe willing to pay what I payed for couple months ago hopefully haha rtx 2070 looks better to me that the new amd radeon VII...
  • 微星科技
« Reply #11 on: 09-January-19, 13:55:08 »
Most likely not. Yes, RTX 2070 looks quite good. As nothing new from AMD has been released anything else is just rumors.
Windows 10 Pro
MSI MAG BUNKER Case
darkhawk
« Reply #12 on: 09-January-19, 21:17:57 »
They're predicting the AMD card will have roughly the same performance as 2080....but more power hungry, probably a bit hotter, and lets face it, it's AMD. Do you really want their drivers with how poor they are? Just saying....
System 3MSI Z390 GodlikeIntel i9 9900K32GB DDR4 @ 3600 MHz MSI RTX 2070 Gaming Z 8GB
