Author Topic: WE62 Vs WE63 with MAYA Software  (Read 668 times)
RaintheDragonessTopic starter
« on: 16-October-18, 18:25:57 »
For anyone who works with the Animation System MAYA/Photoshop, Is there any preference between the WE62 (specifically the 7RJ 1833) and the WE63 (specifically the 8SJ235)? Do either work better with the system or have less to no bugs?
The WE62 has the NVIDIA Quadro M2200 Graphics Card, which is not on the list of recommended for the software, however seems to have the better Chip. The WE63 Has the M2000 which is on the list, however has a slower chip. Does anyone know if either makes a difference?
ace8888
  • SERGEANT
Re: WE62 Vs WE63 with MAYA Software
« Reply #1 on: 12-December-18, 03:53:44 »
as I know that WE63 M2200 is Quadro N17 gen. compared wtih WE62 M2000M gen., the Quadro performance is about 20% enhancement if runs with Autodesk Maya.
grit is the important ingredient to be success.
