Author Topic: Question about GTX 2080 Seahawk X  (Read 543 times)
ssimmons456Topic starter
« on: 30-October-18, 07:31:19 »
Does anyone know if this uses a custom pcb, or is it a reference pcb?  Thank you very much!
  • 微星科技
Re: Question about GTX 2080 Seahawk X
« Reply #1 on: 30-October-18, 11:38:17 »
It is a pure refrence pcb. All normal hybrid cooled Sea Hawk cards use a refrence pcb. Only the Sea Hawk EK models (with EK cooler for a custom loop) of any generation are based on the current Gaming series pcb.
AMD Ryzen 9 3900X
Windows 10 Pro
ethanwang350
« Reply #2 on: 10-January-19, 19:00:20 »
In this case, is the reference RTX 2080 pcb the same as the Founders Edition? I bought the Seahawk X but I'm looking to upgrade to a custom water loop so I'm wondering if EK's reference RTX 2080 water block will fit the Seahawk X if I remove the hybrid AIO.
  • T9246ED
  • Administrator
« Reply #3 on: 11-January-19, 10:17:07 »
yes must be the same
