Author Topic: AM4 PI 1006 BIOS INFO *README*  (Read 5946 times)
darkhawkTopic starter
If you are updating your AM4 motherboard to PI1006 based BIOS, please read the following :
1. If you are using a Raven CPU, you MUST update the chipset driver to version 1810 or newer prior to doing the BIOS update.
    a. if you do not, you will not have a display in your OS, but may have a display during POST and BIOS.
    b. At this time, I am not aware of any workaround if you update to PI1006 with a Raven CPU prior to updating the chipset driver.
2. Another option is to use Live Update, as this will ensure that your chipset driver is updated prior to updating the BIOS.
liviut2003
  • CORPORAL
Re: AM4 PI 1006 BIOS INFO *README*
« Reply #1 on: 09-November-18, 11:19:40 »
I managed to update to 1.J but i have an ryzen 5 1600X, should i downgrade or is it fine?
« Reply #2 on: 09-November-18, 15:30:30 »
Is the Ryzen 5 1600X a Raven CPU? (hint : No, it's not)
Basically, it doesn't matter as much for you. But if you had a Raven CPU,, it would.
liviut2003
  • CORPORAL
« Reply #3 on: 09-November-18, 16:02:29 »
Well as it got removed from the official support download i didn't think it hurt to ask, but i guess it did.
Sorry for bothering.
  • 微星科技
« Reply #4 on: 10-November-18, 06:13:57 »
liviut2003 it probably got removed because MSI can't control who downloads it and so Raven Ridge users might too and run into issues. Most likely seemed too risky. For you - like darkhawk said - it doesn't matter though.
AMD Ryzen 9 3900X
Windows 10 Pro
miklet
  • SECOND LIEUTENANT
« Reply #5 on: 13-November-18, 13:15:06 »
Are there any benefits to users who DO NOT have the Raven Ridge CPU?
Which CPU's is this intended for?
System 1 - Rosewill Stealth Case
MSI X370 Gaming Pro Carbon E7A32AMS.1L0 AGESA PinnaclePI 1.0.0.6
MSI WI-FI/Bluetooth PCIe card MS-8905C
AMD Ryzen 7 2700X auto
Corsair RAM CMW16GX4M2C3200C16W 2x8=16GB OC 3466MHz 16-18-18-36-81-1T 1.4v
EVGA AOI CLC120
EVGA GPU 6GB 1060 v441.12
EVGA PSU 750G3
WD Black NVMe v1.2 M.2 SSD 512GB PCIe Gen3 x4
Windows 10 Home 1903 18362.449
System 2 - Corsair 750D Case
MSI X470 Gaming M7 AC E7B77AMS.1D2 AGESA Combo-AM4 1.0.0.4B
AMD Ryzen 9 3900X auto
Corsair RAM CMU16GX4M2C3200C16B 4x8=32GB XMP 3200MHz
EVGA AOI CLC280
EVGA GPU 8GB 1080FTW v441.12
EVGA PSU G3 1000 watt
WD Black NVMe v1.3 M.2 SSD 512 GB M.2 PCIe Gen3 x4
  • 微星科技
« Reply #6 on: 13-November-18, 13:21:54 »
It is intended for all cpus used on the AM4 chipsets. It is not an update for Raven Ridge but can cause problems with Raven Ridge unless chipset driver is updated. That is all this thread is about.
AMD Ryzen 9 3900X
Windows 10 Pro
veganfanatic
  • SECOND LIEUTENANT
    • HARDCORE GAMES™
« Reply #7 on: 31-March-19, 17:22:51 »
The post suggests a problem with the BIOS itself which should be independent of the CPU installed. Socket AM4 has a finite range of processors so it should not be rocket science to develop a ROM that works.
Cooler Master HAF 932 powered by the Corsair HX1000i PSU
« Reply #8 on: 31-March-19, 17:27:56 »
It suggests that there's a problem. Doesn't mean the "BIOS" is a problem.....more goes into a BIOS than what MSI puts into it. And I'm quite certain that part isn't the problem....and since only 1 other group puts code into it....it really narrows it down. They've been known to deliver poor code too.
