Author Topic: Will i need to update BIOS for this GPU?  (Read 807 times)
joeychau8Topic starter
  • CORPORAL
« on: 25-November-18, 22:11:10 »
Hi
I am about to acquire a new GPU and are wondering if my current bios version support this GPU.
The GPU i am about to buy is: Asus GeForce GTX 1060 Dual OC 2xHDMI 2xDP 6GB
The motherboard i have : p67a-g45 (ms-7673)
Current BIOS version:   V1.19 ,   01.Aug.2012
Thanks =)
  • 微星科技
Yes, for a GTX 10 you will need latest bios 5.4:
Follow the below:
   A.) Download the >>linked archive (!)<< and place it on your desktop. Do not decompress.
   B.) Download and install the >>MSI HQ Forum USB flasher<<
   C.) Insert your FAT32 formatted usb stick.
   D.) Make sure the legacy USB is enabled.
   E.) Start the forum flash tool and select option 1. Then point the tool at the compressed archive we downloaded earlier. Then to your USB Flash Drive.
   F.) Boot to the USB and follow the directions. MEMTEST is included with the forum flash tool and it is recommended to run this prior to any flash.
Windows 10 Pro
MSI MAG BUNKER Case
  • CORPORAL
Re: Will i need to update BIOS for this GPU?
« Reply #2 on: 26-November-18, 15:05:48 »
Thank you for the guidance. But i have never done a bios update before the way you decribed it. But i will try. I am wondering if the LIVE UPDATE 6 bios update is enough or do i have to do it the way you gave me?
  • 微星科技
NEVER use Live Update to update a bios. Bios updates under Windows are taking the risk to the max. You can try other methods if you like however flashing an ME8 bios on a 6 series board can quite easiely go wrong with other methods.
Windows 10 Pro
MSI MAG BUNKER Case
  • CORPORAL
« Reply #4 on: 26-November-18, 15:37:47 »
Ok
So i was thinking of doing this right now. BUT i am still a little scared of doing this, could you try to tell me exact how i am supposed to do it from point D of your guidance previously gaven to me ?
  • CORPORAL
« Reply #5 on: 26-November-18, 15:41:08 »
and when i use the HP USB DISK STORAGE FORMAT TOOL, do i need to create a DOS startup disk ? or just format the usb to FAT32 ?
Also . i forgot which key i have to press to get into bios when starting up my computer (but ill manage to find out unless you got it right here=) ).
  • 微星科技
« Reply #6 on: 26-November-18, 15:47:56 »
The tool creates the bootable stick. It needs to be simply formatted. The tool could even do that (fix my usb key) if needed.
To enter bios press del key.
Windows 10 Pro
MSI MAG BUNKER Case
  • CORPORAL
« Reply #7 on: 26-November-18, 15:50:11 »
What do you mean by enable usb legacy? and how do i do that ?
  • 微星科技
« Reply #8 on: 26-November-18, 15:51:04 »
Don't worry about it. It is enabled by default. If you don't know it you haven't changed it.
Windows 10 Pro
MSI MAG BUNKER Case
  • CORPORAL
« Reply #9 on: 26-November-18, 15:53:25 »
Ok great. so
1.I have the 7673v54.rar file on my desktop
2.my usb is ready
from here i just need to use the MSIHQ software to prep the usb.
After that i turn off the computer and go into bios and tell it to boot from USB ?
  • CORPORAL
« Reply #10 on: 26-November-18, 16:00:37 »
when i run the MSIHQ Tool i get "Error 654: invalid path or file name  the specified path name or file name is invalid. please try again
  • CORPORAL
« Reply #11 on: 27-November-18, 04:21:43 »
I am trying again today but i am still stuck where i was yesterday.
When i run the MSIHQ tool i still get the error 654. with a window asking me " how do you want to open this file"
Please help
  • CORPORAL
« Reply #12 on: 27-November-18, 07:45:08 »
I just want to let you know that i successfully managed to flash the BIOS =)
I dont know what was wrong with the MSIHQ tool, but i used the tool on my laptop to prep the USB.
And the rest was fine too.
Thank you for your help !
  • 微星科技
« Reply #13 on: 27-November-18, 11:06:48 »
You are most likely using Windows 10 1809. It causes this issue therefor it worked on your notebook. Well done! :pompom:
Windows 10 Pro
MSI MAG BUNKER Case
  • CORPORAL
« Reply #14 on: 30-November-18, 13:37:31 »
Hi again Flobelix!
I just received my new GPU today. A ASUS GTX 1060 6GB. i tried to connect it to my computer but it does not display any image. as you know i already updated the BIOS to the latest version 5.4.
Do you know what it could be ?
My pc specs:
          Windows 10  64bit
  • Corsair TX 650W PSU
  • MSI P67A-G45 B3, Socket-1155
  • Intel Core i7-2600 Processor
  • Corsair H40 Hydro Series CPU Kjøler
  • Kingston ValueR. DDR3 1333MHz 8GB, CL9
  • Corsair Value S DDR3 1333MHz 8GB
  • ZOTAC GeForce GTX 570 1280MB PhysX CUDA
  • Corsair SSD Force Series 3, 90GB 2.5"
  • Seagate Barracuda® 7200.12 1TB
  • Sony DVD Writer, AD-5280S
I would also like to mention that i tried to connect my two monitors with 2 HDMI cables. because i dont have a DVI-D (dual link) cable i can connect it with. could this be the problem ?
I dont know if this is relevant but I also checked my Intel Management Engine and it says  driver version 11.0.0.1157.
The fans on the ASUS gtx 1060 6gb does not spin when i turn the pc on either, but there is 1 power indicator that turns on when i connect the power cable to the gpu.  just trying to give as much info as i can
  • 微星科技
« Reply #15 on: 30-November-18, 14:25:39 »
If the fans won't spin on starting the pc the card is very most likely bad. The bios works fine with a GTX 1060. Problem is with the card contact ASUS about it.
Windows 10 Pro
MSI MAG BUNKER Case
  • CORPORAL
« Reply #16 on: 30-November-18, 14:28:43 »
Thank you so much for fast reply =) i will contact the store i bought it from :biggthumbsup:
  • CORPORAL
« Reply #17 on: 30-November-18, 15:15:51 »
Just a quick question before i contact the store. Do i need to uninstall the driver for the old gpu when i put in the new one? Could this also be a reason for the new gpu to not work?
  • 微星科技
« Reply #18 on: 30-November-18, 16:09:21 »
The issue appears before windows starts. Therefor there is no possiblity it could be a driver issue.
Windows 10 Pro
MSI MAG BUNKER Case
  • CORPORAL
« Reply #19 on: 30-November-18, 19:06:12 »
Seems like the fans only start to spin for a split second once i power it up. for some reasons it works now=) thanks for all help ive got ^^ hope someone someone find this helpful (a noob like me):P
