Author Topic: MSI Cubi N Celeron 4GB 32GB SSD  (Read 872 times)
AndieBTopic starter
« on: 27-November-18, 11:05:35 »
Hi!
Just purchased a Cubi N Celeron 4GB 32GB SSD and want to install a harddrive.
Is it only M.2 SSD that fits or do a traditional 2,5" SSD work too?
What shall I choose?
Same goes for memory. What memory shall I purchase?
Thanks in advance!
//Andreas
Mog
  • AIO Moderator
Re: MSI Cubi N Celeron 4GB 32GB SSD
« Reply #1 on: 08-January-19, 20:57:42 »
Hi Andreas,
Do you purchase Cubi N 8GL product? https://www.msi.com/Desktop/Cubi-N-8GL/Specification
If yes, you can go to product support link https://www.msi.com/Desktop/support/Cubi-N-8GL then select product service of "recommend" on left banner for more detail. Thanks.
