Pages: 1 [2]  All   Go Down
Author Topic: How to clear the CMOS  (Read 760097 times)
0 Members and 4 Guests are viewing this topic.
SvetTopic starter
  • T9246ED
  • Administrator
Re: How to clear the CMOS
« Reply #50 on: 07-August-14, 12:41:40 »
@erick.simple.08@gmail.com
if you have some issue, open new topic in proper section
describe the issue and also list full detailed system specifications, see >>Posting Guide<<
jringo8769
  • Live every day to the fullest....Thank God
« Reply #51 on: 12-February-15, 18:49:22 »
Well i have a x320 how do i go about clearing the cmos on that one...any help will be so appreciated...God Bless John
SvetTopic starter
  • T9246ED
  • Administrator
« Reply #52 on: 13-February-15, 06:35:41 »
this do not apply for notebooks
you no need to clear cmos if you have a notebook
jringo8769
« Reply #53 on: 17-February-15, 00:30:01 »
well maybe this is the better question....when i try and start this laptop up...it does not recognize the hard drive and i was told resetting the bios should fix it....any help will be so appreciated...God Bless John
SvetTopic starter
  • T9246ED
  • Administrator
« Reply #54 on: 17-February-15, 05:12:08 »
open new own topic in notebook section if you need help with your notebook
debynory
« Reply #55 on: 14-March-15, 09:32:15 »
In my MSI A88XM-E45 there isn't jumper, it's normal? To clear CMOS I have to remove for 4-5 minutes the battery..
Board: A88XM-E45
Bios: V25.0 (11/21/2013)
PSU: Thermaltake Munich PSU, 430W
CPU: AMD FM2+ A10-7700K with Radeon R 7 Graphics 3,40ghz
RAM: 2 x 2GB Corsair Simm DDR3 PC1333, CL9, VS2GB1333D3
HDD: MAxtor SATA II 250 GB 7200 RPM 8mb cache
OS: Windows 7 64bit Ultimate SP1
SvetTopic starter
  • T9246ED
  • Administrator
« Reply #56 on: 14-March-15, 09:53:33 »
there is a jumper near to the battery, called JBAT1
philrazo
  • CORPORAL
« Reply #57 on: 15-April-15, 15:44:28 »
The instructions are from 2009, are these instructions still applicable w/ the newer motherboards?
Nichrome
« Reply #58 on: 15-April-15, 15:51:16 »
Usually yes. However refer to the actual manual available online on product site, or inside your motherboard box.
Becketo
« Reply #59 on: 03-June-15, 03:03:08 »
Zefie's 8 step Clear CMOS worked perfectly.  My motherboard is Z77 MPOWER Military Class.  Now Bios switches A/B are working perfectly.
Bravo my friend your a life saver. :worship:
Bios: Version (A switch) 17.6 E7751IMS (B switch) 17.12 E7751IMS
VGA:  Geoforce GTX 275
PSU:  (Owltech) Seasonic X Series(Fanless) SS460 Full Range 100 - 240V (Max.90-264V),63A, 50/60Hz
Intel Core i7-3770K 3.50 Ghz,8MB Cache, LGA 1155 77W (Ivy Bridge)
MEM: Corsair CMZ16GX3M2A16000C10 DDR3-1600 (800MHZ)
SSD: Crucial M4 256GB (CT256M4SDD2)
SSD: Crucial M4 128GB (CT128M4SDD2)
HDD: WDC WD20EZRX-0 (200GB)
COOLER: Antec25 Kuhler h2O 920
OC:
OS: Windows 7 64bit Ulitmate
throwawaygf
« Reply #60 on: 15-August-15, 13:25:15 »
I followed the procedure to clear the CMOS and for good measure, also replaced the battery. Now I can get to the boot menu by hitting the F11 key, but the computer still doesn't boot. I can also hit the <DEL> key and it says that it is entering setup, but doesn't. Any ideas? This all started with a automatic reboot during the upgrade to Windows 10.
  • 微星科技
« Reply #61 on: 15-August-15, 17:33:45 »
This thread is not for troubleshooting. Stick to your thread you already opened. >>Please read and comply with the Forum Rules.<<
Windows 10 Pro
MSI MAG BUNKER Case
vegetadbzfinalflash
  • CORPORAL
« Reply #62 on: 23-October-16, 22:22:04 »
after i updated my BIOS my sound doesn't work and my screen looks weird then i tried loading up a game and it said graphics card is outdated none of this occurred " before i did any updates to my BIOS "
so if i do the first one will my sound be restored and my screen will look fine as it did before?
  • 微星科技
« Reply #63 on: 24-October-16, 02:25:13 »
Please open your own thread.
Windows 10 Pro
MSI MAG BUNKER Case
Pages: 1 [2]  All   Go Up
