Author Topic: I cant login to forum from my dsl connection  (Read 789 times)
sinanbeyTopic starter
  • STAFF SERGEANT
« on: 25-December-18, 11:55:13 »
I am having a impossible time logging into forum from my dsl connection as my 10 years of msi forum account has been marked as a spammer for any reason that is not my fault at all. I need moderation team to solve this and let me enjoy msi forums as i used to enjoy. Thanks.
MSI NIGHTBLADE MI2-020EU
INTEL® CORE™ i7-6700 CPU
16GB CORSAIR VENGEANCE DDR4 2400MHZ
MSI GTX960 GAMING 4GB
X300 SANDISK 256GB SSD
4TB Seagate ST4000VX000
1TB Seagate ST31000524AS
badboy2k
Re: I cant login to forum from my dsl connection
« Reply #1 on: 25-December-18, 12:20:50 »
what was your user name on the forum so i can look into it?
Cooler: corsair H100 cooler
  • STAFF SERGEANT
« Reply #2 on: 26-December-18, 05:50:37 »
sinanbey
Thank you. I can login from my cellphone but not from the home dsl. I am reported to be a spammer. Lol
Nichrome
« Reply #3 on: 26-December-18, 15:09:11 »
Can you send me your home IP via private message? I'll check it.
https://valid.x86.fr/mbld36
darkhawk
« Reply #4 on: 26-December-18, 15:58:57 »
There's been a ton of issues lately with the forums....Trust me, we've all been running into issues.
Please provide your info to Nichrome and we will look into fixing the issue.
System 3MSI Z390 GodlikeIntel i9 9900K32GB DDR4 @ 3600 MHz MSI RTX 2070 Gaming Z 8GB
For You
  • SECOND LIEUTENANT
« Reply #5 on: 27-December-18, 10:24:06 »
I have the same problem with my WI-FI modem.
I can access MSI forum if I use my mobile ISP though. (4G - LTE you know.)
Otherwise it says "Sorry guest you are banned. Spam. The ban is not to set expire" or something like that.
Clearing cache or cookies, trying with different browsers etc. things don't solve it.
I have contacted MSI OCSS but they haven't found the problem yet.
  • STAFF SERGEANT
« Reply #6 on: 28-December-18, 13:46:58 »
I have pm'd my ip address. Looking for a solution asap. Thanks.
Nichrome
« Reply #7 on: 28-December-18, 16:41:19 »
I checked forum logs, but your IP (or IP range) is not banned from forum side.
Will see what MSI says. Might be few days though, new year coming by..
For You
  • SECOND LIEUTENANT
« Reply #8 on: 29-December-18, 07:52:54 »
My problem has been solved.
I lost my internet connection a few days ago due to ISP problem.
When they solved it, my forum ban problem is also solved interestingly.
Seems like dynamic IP, DNS or something like that have changed. I dunno. But I can enter MSI forum flawlessly and happily again right now.
:pompom:
badboy2k
« Reply #9 on: 29-December-18, 16:16:57 »
My problem has been solved. I lost my internet connection a few days ago due to ISP problem. When they solved it, my forum ban problem is also solved interestingly. Seems like dynamic IP, DNS or something like that have changed. I dunno. But I can enter MSI forum flawlessly and happily again right now. :pompom:
your IP is still the same one that was causing the issue. either MSI fixed it there end or your ISP had a bad DNS that was triggering a automated response that they fixed!
  • STAFF SERGEANT
« Reply #10 on: 02-January-19, 12:21:34 »
My problem is still not solved. I need to access this forum.
  • STAFF SERGEANT
« Reply #11 on: 04-January-19, 13:14:26 »
Is there a progression for my issue ? I still cant access the forum.
Nichrome
« Reply #12 on: 04-January-19, 15:26:04 »
Not at the moment :undecided:
MSI is working on fixing few bits and pieces that might be affecting unknown bans to occur.
  • STAFF SERGEANT
« Reply #13 on: 11-January-19, 13:21:52 »
Hey Nichcrome,
My problem is finally solved. I can enjoy the forums once again. To be honest, i expect some kind of apology from msi webteam for flagging a 25 year customer and 15 years of forum user like me as a spammer for nothing.
Thanks for your support.
my first ever msi product is ms-6119 440bx board and since then a happy msi customer.
darkhawk
« Reply #14 on: 11-January-19, 18:03:30 »
Hey Nichcrome,
Unfortunately I wouldn't expect anything.....
Trust us, it's not like we don't tell them about things going on, and wait weeks, months for things to get fixed.
Be happy it works, post, and hope they don't break it again. That's really the best we can say. :)
