Author Topic: MSI X470 Gaming Plus Bios With Offset voltage  (Read 1025 times)
gerardfraserTopic starter
  • SERGEANT
« on: 06-January-19, 20:12:21 »
Just looking to see if anyone has a copy of MSI X470 Gaming Plus Bios With Offset voltage .I know it is just the user forum here,I thought no harm in asking.
Thanks
plutomate
  • COLONEL
Re: MSI X470 Gaming Plus Bios With Offset voltage
« Reply #1 on: 08-January-19, 23:15:53 »
you can update to the latest BIOS and it should have the offset option, just click on CPU Core Voltage and it'll let you select override, auto or offset mode. but make sure you know wut you're doing, usually i'd prefer to use override mode if i want to change vcore.
miklet
  • SECOND LIEUTENANT
« Reply #2 on: 09-January-19, 18:21:34 »
where can users learn about the OFFSET ability?
System 1 - Rosewill Stealth Case
MSI X370 Gaming Pro Carbon E7A32AMS.1L0 AGESA 1.0.0.6
MSI WI-FI/Bluetooth PCIe card MS-8905C
AMD Ryzen 5 1600 OC 3.875GHz
Corsair RAM CMW16GX4M2C3200C16W 2x8=16GB OC 3466MHz 16-18-18-36-81-1T 1.4v
EVGA AOI CLC120
EVGA GPU 6GB 1060 v430.86
EVGA PSU 750G3
WD SSD 512GB M.2 PCIe Gen3 x4 Black (2017)
Windows 10 Home 1903 18362.145
System 2 - Corsair 750D Case
MSI X470 Gaming M7 AC E7B77AMS.180 AGESA 0.0.7.2
AMD Ryzen 7 2700X auto settings
Corsair RAM CMU16GX4M2C3200C16B 4x8=32GB XMP1 2933MHz
EVGA AOI CLC280
EVGA GPU 8GB 1080FTW v430.86
EVGA PSU 850 watt G3
WD SSD 512 GB M.2 PCIe Gen3 X4 Black (2018)
  • SERGEANT
« Reply #3 on: 11-January-19, 23:32:21 »
CPU Offset voltage is useful for PBO overclocking on the 2700X/2600X. The stock voltage can be set  too high by Ryzen, so using a negative CPU Offset voltage,  allows the Motherboard to use less power and turbo higher and may lower temperatures on CPU.
Also google will show the way for a better answer.
Thanks for the reply,but there is no CPU offset voltage on the X470 Gaming Plus/Pro.
There is though in X370 Gaming Plus/Pro and some B350 Motherboards.Msi just started rolling the Bios out in the last week or two. So that is why I was asking ,I can wait until it is released .
Edit: LOL Just checked the new BIOS is up with CPU Offset voltage.
PBO Working very well.
Msi x470 Gaming Plus
2600X
CPU Off Set-1.0v holding 4250Mhz gaming
CPU running 1.26v-1.28v,now time to go try a real overclock.
