Author Topic: BIOS for Armor RX570 4GB  (Read 1319 times)
ctmnismoTopic starter
« on: 06-January-19, 23:32:35 »
S/N1: 602-V341-260B1710000530
CHK: 627
Thanks
  • T9246ED
  • Administrator
Re: BIOS for Armor RX570 4GB
« Reply #1 on: 07-January-19, 13:40:06 »
can you elaborate more?
what bios do you need?
« Reply #2 on: 07-January-19, 23:45:22 »
Sorry just need the stock one. Bought it used and AMD drivers don't recognize the card even though its "working".
ragnar.laud
« Reply #3 on: 08-January-19, 01:20:00 »
Same here.
Bought the exact same card yesterday, but it didn't even get recognized, and GPU-Z showed some crazy stuff
S/N: 602-V341-122SB1705005583
CHK: 076
  • T9246ED
  • Administrator
« Reply #4 on: 08-January-19, 11:33:03 »
I'm attaching correct and latest vbios for your card below
@ragnar.laud
open new own topic
« Reply #5 on: 08-January-19, 21:02:24 »
Downloaded the file and use WinRAR to extract. Added ".rom" to the end of the file name and removed the "." before 5E3. Then used ATIWinflash to flash the bios and it seemed fine until rebooting. The system now hangs and wont send a signal to the monitor, even if using the integrated HDMI port on the motherboard, with the 570 installed.
  • 微星科技
« Reply #6 on: 09-January-19, 11:36:58 »
You renamed TV341MH.5E3 to TV341MH5E3.rom or TV341MH.5E3.rar to TV341MH5E3.rom?
AMD Ryzen 9 3900X
Windows 10 Pro
« Reply #7 on: 10-January-19, 14:27:08 »
WinRAR had file name as "TV341MH.5E3". I changed it to "TV341MH5E3.rom" when extracting.
  • T9246ED
  • Administrator
« Reply #8 on: 10-January-19, 15:23:23 »
looks like something is wrong with the card then
or its vbios chip is corrupted
taygunkanber
« Reply #9 on: 17-March-20, 12:27:06 »
Hello, , i need latest vbios stock rom pls.
S.N= 602-V341-345SB1903008424 CHK: 7F6
  • 微星科技
« Reply #10 on: 17-March-20, 13:29:34 »
Don't hijack other threads but open your own.
:floblock:
AMD Ryzen 9 3900X
Windows 10 Pro
