Author Topic: BIOS PLZ? GTX 1070 MICRON  (Read 575 times)
moptopjesseTopic starter
« on: 08-January-19, 02:37:07 »
So my fricking GTX 1070 with this garbage MICRON ram has always had little problems and now I'm playing games that give even WORSE problems like so much crashing It's unplayable.. so I'm trying to figure crap out and well these MSI pricks are NO HELP AT ALL SO FAR. I've tried their only public support I could find, being the 391.01 driver.. well with that installed, everything runs like complete dogshit and was doing much better apart from crashes when running whatever GEForce experience was updating me with. So now with your driver, my GTX 1070 can't run Hunt: Showdown on LOWEST settings with 1080p without consistent horrible framerate and big framedrops and stuttering. Hoping maybe I can use the EVGA update or someone else's but I'm worried they wont work with my MSI card. So.. can I get some help?!?!? I've spent so much time trying to figure this crap out I'm about to lose it. One thing is for sure I'll never buy anything from MSI unless I can get this resolved.
Nichrome
Re: BIOS PLZ? GTX 1070 MICRON
« Reply #1 on: 08-January-19, 06:34:46 »
Provide S/N of the card (skip last 3 digits), and add a copy of current vBIOS  (GPU-z => Extract / save to file).
https://valid.x86.fr/mbld36
  • T9246ED, Бивша комета
  • Administrator
« Reply #2 on: 08-January-19, 11:37:28 »
also list system specs, see >>Posting Guide<<
« Reply #3 on: 09-January-19, 03:13:27 »
Sorry for the rage I have been having a very difficult time with this.
S/N: 602-V330-220B1701012283
Can not link from GPU-Z because it will only save as a rom file and I guess I can't send those. But the display shows 86.04.50.00.2A
Hopefully this is enough for now I don't have time for all the rest at the moment. Thank you for your time guys
Nichrome
« Reply #4 on: 09-January-19, 04:30:22 »
Try this with NVflash instead:
nvflash /v >rep.txt [ENTER]
And upload .txt file
« Reply #5 on: 09-January-19, 08:49:02 »
Well, after getting pissed off nearly to meltdown stage I finally figured out how to enter your command, and I get this..
"ERROR: Filename must have a valid extension. [ .nvr .rom .bnv ]"
  • 微星科技
« Reply #6 on: 09-January-19, 11:19:41 »
That is exactly what we need. Simply .zip or .rar the rom file and attach it.
The rep.txt is useless for GTX 10.
Core i7 7820X @ 4302.24 MHz (43 * 100.05 MHz, fixed all cores), 1.126v - delidded and using der8auer Skylake-X Direct Die Frame
MSI GeForce RTX 2080 GAMING X TRIO --> MSI GeForce GTX 1080 Ti GAMING 11G
Windows 10 Pro
MSI MAG BUNKER
darkmdc
  • STAFF SERGEANT
« Reply #7 on: 09-January-19, 11:37:00 »
you also can open the ROM file with notepad and search vor keyword "version" and copy the line with your bios version,
(just if he dont know how to zip or rar ^^)
Intel i7 9700K
MSI MPG Z390 Gaming Plus  / Bios 1.40
MSI RTX 2080 Gaming Trio X  8G / Bios 105
Plextor M6e m.2 SSD 128GB firmware 1.05 / Win10 Pro x64
Crucial SSD BX300 480GB (games)
Crucial SSD BX500 480GB (games)
16GB G Skill AEGIS - DDR4 3000Mhz Dual Channel -XMP Profile 3000Mhz activated
External 3TB USB3.0 drives (data,backups)
Sony 55XE7005 4K HDR
Samsung SH-B123L/BSBP Blu-ray Combo Drive
Logitech G810 Orion Spectrum RGB mechanical Keyboard
Logitech G900 Chaos Spectrum RGB Mouse
Enermax Revolution X't 630W, ERX630AWT 80plus Gold
Creative Soundblaster Z PCIe
« Reply #8 on: 09-January-19, 13:37:27 »
Thanks for clarification
  • 微星科技
« Reply #9 on: 09-January-19, 13:56:38 »
You are using version NV330MH.241. Latest is NV330MH.242: https://forum-en.msi.com/index.php?topic=302551.msg1755476#msg1755476
Windows 10 Pro
MSI MAG BUNKER
« Reply #10 on: 10-January-19, 02:42:37 »
Okay well.. I followed instructions to the T and when I ran it, my screen turned black, lost connection to monitor and never returned. I waited 15 minutes and then tapped the power button for a 'soft'(?) reset. After rebooting I found my GPU 'disabled'. So I able it and do the restart, it appears to be ok right now, attaching new exported bios to make sure it worked, thanks again for your time.
  • 微星科技
« Reply #11 on: 10-January-19, 11:27:39 »
Maybe you forgot to attach it?
Windows 10 Pro
MSI MAG BUNKER
« Reply #12 on: 10-January-19, 17:04:27 »
Omgosh.. forgive me I was very tired.
  • 微星科技
« Reply #13 on: 11-January-19, 10:22:33 »
It didn't flash, still at NV330MH.241
Windows 10 Pro
MSI MAG BUNKER
« Reply #14 on: 12-January-19, 03:42:14 »
Gotcha, well I entered the command 'nvflash64 -6 242.rom' with the nvflash program and the rom right inside c:.
When I search how to do a flash everyone seems to suggest 'nvflash64 -5 -6 xxx.rom'
Would you say it's safe to add the -5? All the warnings about bricking your GPU scare me..
  • 微星科技
« Reply #15 on: 12-January-19, 06:36:38 »
-5 doesn't work anymore. Flash again normally last time obviously simply failed.
Windows 10 Pro
MSI MAG BUNKER
« Reply #16 on: 13-January-19, 00:43:15 »
Well it seems to be simply failing for a good reason because it just does the exact same thing, I enter command, I see new text on cmd for a split second, screen goes black, windows disconnect device sound, nothing until I press power button to reset, and power on to my GPU disconnected. So.. any other ideas..? :undecided:
  • 微星科技
« Reply #17 on: 13-January-19, 05:02:41 »
Most likely the card is simply bad then.
Windows 10 Pro
MSI MAG BUNKER
