Author Topic: overheating gp73 CPU  (Read 586 times)
dragnetblTopic starter
  • CORPORAL
« on: 08-January-19, 10:07:36 »
I have problem whit overheating cpu.
To test temparatures i use msi after burner.
When i play cs:go, cpu temp are going up to 95C, but CPU usage is only about 25%
Fans are working all time, but temparatures are so high.
ersin
  • SECOND LIEUTENANT
Re: overheating gp73 CPU
« Reply #1 on: 08-January-19, 10:42:58 »
The thermal paste probably not working properly. I would suggest re pasting cpu/gpu. Try not to keep those high temps going or you can cause damage. Also open the back of your laptop do a cleaning for dust as an alternative but re pasting still needed.
Dont Forget To Marked As Best Solution for answers that solved your issue.
FAQ : https://www.msi.com/faq
Use MSI HelpDesk to export system information
You can find the latest version of HelpDesk in the download link below.
http://download.msi.com/uti_exe/nb/helpdesk.zip
Owner of a GT62VR-7RE
https://www.msi.com/Laptop/GT62VR-7RE-Dominator-Pro/Overview
annet
  • CAPTAIN
« Reply #2 on: 09-January-19, 05:26:32 »
Does this only happen when you're playing cs:go or it also happens when playing other games?
Any lags or freezing happens when the temp reaches 95 degrees?
Try using HWinfo to monitor the temperature, save the log file and attach it here (along with your system information file exported from MSI help desk).
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
« Reply #3 on: 09-January-19, 11:43:23 »
Some games are CPU  heavy ... Some games are GPU heavy.
Does this temp issue occur with other games?
Also, adjust the fan curve in Dragon Center to something more aggressive.
  • CORPORAL
« Reply #4 on: 12-June-19, 06:26:58 »
If i use android studio, my temps are going above 95c
Not sure if i need to change thermal paste, i dont use this laptop much. It dont have more than 30 work hours.
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
« Reply #5 on: 12-June-19, 11:37:45 »
CPU or GPU, or Both?!
  • CORPORAL
« Reply #6 on: 18-June-19, 03:13:38 »
Only cpu
GPU temps are 75c (max that i see)
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
« Reply #7 on: 18-June-19, 10:54:50 »
Only cpu
Check Dragon Center and see if it is set to Turbo Mode.
Change to Sport and Advanced for fan speed control.
Make you fan speed ramp a bit more aggressive.
  • CORPORAL
« Reply #8 on: 20-August-19, 03:23:43 »
Hello, i have do all that.
Also i repaste my laptop whit IC Diamond, but still temparatures on CPU are soo high
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
« Reply #9 on: 21-August-19, 11:28:17 »
Buy a laptop cooler.
Buy a notebook that has better cooling GT75 or GT76.
Use a desktop that has better cooling.
