Author Topic: Registration question  (Read 126 times)
vtrousilTopic starter
« on: 09-January-19, 06:17:51 »
Hi guys new here. I wanna register my mobo MPG Z390 Gaming Plus  however is need my 3 or 4 digit code as addition to my Serial # which is printed on Power supply connector This is covered with my case bracket and I cant read it. Otherwise I have to remove whole mobo from case for that to see it. Is there another solution how to get it this code for me to complete my registration. Sorry if I post this in wrong section. Thank for help
Vlad
  • 微星科技
Re: Registration question
« Reply #1 on: 09-January-19, 11:58:01 »
The S/N is to be found on a sticker on the box too.
Core i7 7820X @ 4203.84 MHz (42 * 100.09 MHz, fixed all cores), 1.086v
MSI GeForce RTX 2080 GAMING X TRIO
Corsair HX1200i • +12V: 100A • +3.3V: 30A • +5V: 30A
Windows 10 Pro
Cooler Master Masterbox 5 MSI Edition
« Reply #2 on: 09-January-19, 22:47:05 »
Thanks for reply However CHK 3digit number is not on the box label and is covered by my case bracket I need some other place to find this missing part of my registration. Thanks
hiatusonsaturday
« Reply #3 on: 09-January-19, 23:09:35 »
login with live update app, it will auto regist your motherboard
« Reply #4 on: 11-January-19, 17:32:45 »
Thank you for idea. However when I try to install Live Update 6 after selecting language poped ".....This appy is not for your mobo???" .....well I'm stuck again Any other option? Appreciate
Vlad
jkeifer3
« Reply #5 on: 13-January-19, 06:26:33 »
I appreciate your frustration.  My three digit code is also obscured.  Why MSI needs this for registration is beyond me!! Silly stuff!  Save your receipt and they cannot deny your warranty claim.
« Reply #6 on: 13-January-19, 17:55:55 »
I solved it myself. Just download "Registration Helper Appy" and do not need any stupid CHK #. That SIMPLE !!!!!
plutomate
  • COLONEL
« Reply #7 on: 13-January-19, 20:24:56 »
might come too late since you already solve it, but for z390 board, you need to use Dragon Center instead of LiveUpdate for easy registration. :agrees:
