Author Topic: last vBIOS for MSI GTX 1070 8GB Gaming X  (Read 154 times)
dataTopic starter
« on: 09-January-19, 17:09:26 »
I would like to request the newest vBIOS along with instructions on how to flash it on Windows 10 x64.
My card is based on Micron memory with no particular issue yet.
thanks in advance for your help.
Product Name: MSI GeForce GTX 1070 GAMING X 8G
Serial Number: 602-V330-V270B1611001879
Current vBIOS is attached.
BIOS Version - 86.04.50.00.02C
Release Date - May 30,2016
* GP104.zip (153 kB - downloaded 47 times.)
  • 微星科技
Re: last vBIOS for MSI GTX 1070 8GB Gaming X
« Reply #1 on: 10-January-19, 11:55:23 »
You are using vbios versioN NV330MH.1Z1. Latest is NV330MH.1Z2.
For flashing use nvflash: https://www.techpowerup.com/download/nvidia-nvflash/
note that you need to rename the unpacked file NV330MH.1Z2 to .rom (e.g. 1Z2.rom) for flashing.
If you saved the nvflash for windows .exe say under drive d: you can start it in a Windows prompt in administrator mode after you saved the .rom at the same place. First type d: (or wherever you saved nvflash and the .rom) and press enter. Now you changed to drive d: where you have nvflash in the root directory. Now start the flash with the following line: nvflash -6 1Z2.rom (press enter)
Note that if using a 64bit OS you'll need to run the line nvflash64 -6 1Z2.rom
Core i7 7820X @ 4302.24 MHz (43 * 100.05 MHz, fixed all cores), 1.126v - delidded and using der8auer Skylake-X Direct Die Frame
MSI GeForce RTX 2080 GAMING X TRIO --> MSI GeForce GTX 1080 Ti GAMING 11G
Windows 10 Pro
MSI MAG BUNKER
dataTopic starter
« Reply #2 on: 10-January-19, 16:30:27 »
thank you, it worked like a charm
C:\nvidia-bios>nvflash64 -6 1Z2.rom
NVIDIA Firmware Update Utility (Version 5.541.0)
Copyright (C) 1993-2018, NVIDIA Corporation. All rights reserved.
Checking for matches between display adapter(s) and image(s)...
Adapter: GeForce GTX 1070     (10DE,1B81,1462,3301) H:--:NRM  S:00,B:01,D:00,F:00
EEPROM ID (C2,2533) : MX MX25U4033E 1.65-2.0V 4096Kx1S, page
Current      - Version:86.04.50.00.2C ID:10DE:1B81:1462:3301
               GP104 Board (Normal Board)
Replace with - Version:86.04.50.40.DF ID:10DE:1B81:1462:3301
Update display adapter firmware?
Press 'y' to confirm (any other key to abort):
Storing updated firmware image..
[==================================================] 100 %
Primary image flashing completes.
Verifying update...
Update successful.
Firmware image has been updated from version 86.04.50.00.2C to 86.04.50.40.DF.
A reboot is required for the update to take effect.
C:\nvidia-bios>
  • 微星科技
« Reply #3 on: 11-January-19, 10:21:29 »
:hat tip: great, glad I could help
Windows 10 Pro
MSI MAG BUNKER
