Author Topic: Issue wheb changing response time on MAG24C  (Read 485 times)
buikje-azieTopic starter
« on: 10-January-19, 02:21:37 »
Hey,
I bought the MAG24C which is a 144hz 1ms monitor. The issue I'm having is that when I put the response time at its fastest option the brighteness goes down, and I can't change it. The only way to get the option to change my brightness is to change it back to its slowest response time. Is my monitor defective? Thanks for the help!
Yang
  • AIO Moderator
Re: Issue wheb changing response time on MAG24C
« Reply #1 on: 10-January-19, 19:47:50 »
Brightness will be locked whem response tiom is Normal or Extreme.
Attachment is on manual.
https://www.msi.com/monitor/support/Optix-MAG24C
sapphirebear1
« Reply #2 on: 19-February-19, 10:49:39 »
Brightness will be locked whem response tiom is Normal or Extreme. Attachment is on manual. https://www.msi.com/monitor/support/Optix-MAG24C
1) When I choose Game>Mode before choose Response time - settings will be saved with the mode i chose, but if I'll do response time first -  i can't choose Mode. Is it OK ?
2)About response time - if Extreme = 1ms, what Normal and Off equals?
Yang
  • AIO Moderator
« Reply #3 on: 19-February-19, 19:02:34 »
Response time is need under some special condition so some setting value will be locked.
