Author Topic: Request BIOS Update for MSI Radeon RX 580 Armor MK2 8G OC  (Read 711 times)
geoffcuzTopic starter
Hi
I am looking for the latest BIOS Update for my 2x MSI Radeon RX 580 Armor MK2 8G OC can anyone help me?
602-V341-1210B1804000174
602-V341-1250B1803001709
  • 微星科技
Re: Request BIOS Update for MSI Radeon RX 580 Armor MK2 8G OC
« Reply #1 on: 10-January-19, 11:57:39 »
Add the current vbios of each card saved to file.
AMD Ryzen 9 3900X
Windows 10 Pro
« Reply #2 on: 11-January-19, 00:40:36 »
Hi Flobelix
I have attached the one that I updated them with.
  • 微星科技
« Reply #3 on: 11-January-19, 10:38:11 »
Yeah, you are using vbios version TV341MH.653 which is completely wrong. You are lucky cards still work.
The latest correct vbios for both cards is TV341MH.6C0. It is attached.
For flashing ATIWinflash in Windows. Should explain itself.
Note that you need to rename the vbios file to .rom for flashing after unpacking.
AMD Ryzen 9 3900X
Windows 10 Pro
« Reply #4 on: 11-January-19, 11:16:03 »
Thanks Flobelix for your Help I really appreciate it !
  • 微星科技
« Reply #5 on: 11-January-19, 12:45:01 »
:hat tip:
AMD Ryzen 9 3900X
Windows 10 Pro
