Author Topic: BIOS Request RTX 2080 Ti Ventus OC  (Read 964 times)
WazabiTopic starter
  • CORPORAL
« on: 10-January-19, 15:16:09 »
I was wondering if there was a bios update available for my videocard.
Kind regards,
Danny
  • 微星科技
Re: BIOS Request RTX 2080 Ti Ventus OC
« Reply #1 on: 11-January-19, 10:54:05 »
No way to tell with these informations.
Add the card's S/N and a copy of the current vbios saved to file. The screenshot is useless.
AMD Ryzen 9 3900X
Windows 10 Pro
WazabiTopic starter
  • CORPORAL
« Reply #2 on: 11-January-19, 11:16:42 »
NP!
I've included my current BIOS and my S/N is: 602-V371-07SB1811000087
Thanks!
  • 微星科技
« Reply #3 on: 11-January-19, 12:49:24 »
You are using vbios version NV371MH.132. It is the latest already so there is no update.
AMD Ryzen 9 3900X
Windows 10 Pro
WazabiTopic starter
  • CORPORAL
« Reply #4 on: 16-July-19, 07:48:35 »
6 months later.. Is there maybe a new bios version now? Thanks!
  • 微星科技
« Reply #5 on: 16-July-19, 12:11:17 »
No, there is no update. Vbios aren't updated on a regular basis but only if there is need to.
AMD Ryzen 9 3900X
Windows 10 Pro
