Author Topic: Need new vBios for 1060 3GT OC  (Read 288 times)
guidingleaderTopic starter
    • Indie Game Dev
« on: 10-January-19, 23:04:25 »
I have a MSI GeForce GTX 1060 3GT OC S/N: 602-V809-724SD1608132280.  Attached is my current vBios.  I need a updated Bios to be able to connect to my 4K monitor and get 4K resolutions.  I attempted to run the Live Update 6.2.0.50; and receive a Motherboard not supported error.  Please advise, Thank you for your help.
Board: Dell 0PTTT9 (Precision T3600)
BIOS:  A17
VGA:   MSI GTX 1060 3GT OC
PSU:  Dell NVC7F (12V 18A per rail x 5 rails) Max continuous power 635W
CPU:  Intel® Xeon™ E5-2670 Processor
MEM: 4x4GB, 1333MHz ECC/Reg CL9 Kingston KVR1333D3D4R9S/4GEF 1.5V
HDD/SSD: Crucial MX300 525GB 3D NAND SATA
COOLER: Dell OEM Precision T3600 1TD00
Keyboard: Razor BlackWidow Ultimate
Mouse: Cool Master Devastator 3
OC:  None
OS: Windows 10 64bit Professional
  • 微星科技
Re: Need new vBios for 1060 3GT OC
« Reply #1 on: 11-January-19, 10:59:51 »
You are using vbios version NV809MH0.600. Latest is NV809MH0.601: https://forum-en.msi.com/index.php?topic=284386.msg1610537#msg1610537
AMD Ryzen 9 3900X
Windows 10 Pro
    • Indie Game Dev
« Reply #2 on: 13-January-19, 08:42:51 »
Thank you so much, it updated perfectly and is now running 4k HDMI output.
BIOS:  A17
OC:  None
  • 微星科技
« Reply #3 on: 13-January-19, 09:06:30 »
:hat tip:
AMD Ryzen 9 3900X
Windows 10 Pro
