Author Topic: 1050ti 4gb OC  (Read 198 times)
rick0246Topic starter
1050ti 4gb OC
« on: 11-January-19, 02:16:53 »
My nephew just gave me his 1050ti 4gb OC and well he was a complete noob at taking the card out of the computer...he pulled on the power connector until it broke off...the solder came right off along with the 6 pin..is there a way to fix this..or is the card basically bricked?
  • Online Online
  • 微星科技
Re: 1050ti 4gb OC
« Reply #1 on: 11-January-19, 10:49:52 »
Well, if you can solder you can fix it, else the card is dead.
AMD Ryzen 9 3900X
Windows 10 Pro
  • T9246ED
  • Administrator
Re: 1050ti 4gb OC
« Reply #2 on: 11-January-19, 13:40:51 »
or if you don't feel confident,
then best bring it to some repair shop and let the Pro fix it for you
