Author Topic: (Bios request) RTX 2070 armor  (Read 1672 times)
SilikonTopic starter
« on: 11-January-19, 05:06:11 »
after conversation with nvidia support i want to ask for v-bios (conversation is attached), i will glad for some information about it, i never do that. Thanks you in advance.
  • 微星科技
Re: (Bios request) RTX 2070 armor
« Reply #1 on: 11-January-19, 10:53:09 »
Add the card's S/N
AMD Ryzen 9 3900X
Windows 10 Pro
« Reply #2 on: 11-January-19, 13:17:31 »
S/N 602-V373-22SB1810002614
  • 微星科技
« Reply #3 on: 11-January-19, 13:24:47 »
You are using vbios version NV373MH.200. Latest is NV373MH.203.
For flashing use nvflash: https://www.techpowerup.com/download/nvidia-nvflash/
note that you need to rename the unpacked file NV373MH.203 to .rom (e.g. 203.rom) for flashing.
If you saved the nvflash for windows .exe say under drive d: you can start it in a Windows prompt in administrator mode after you saved the .rom at the same place. First type d: (or wherever you saved nvflash and the .rom) and press enter. Now you changed to drive d: where you have nvflash in the root directory. Now start the flash with the following line: nvflash -6 203.rom (press enter)
Note that if using a 64bit OS you'll need to run the line nvflash64 -6 203.rom
AMD Ryzen 9 3900X
Windows 10 Pro
« Reply #4 on: 11-January-19, 14:06:01 »
Last questions i dont know if you read that pdf documment attached but will i lose warranty if i flash that v-bios ? Because i have problem with that graphics card and that could be problem if that will not repair that defect.
  • 微星科技
« Reply #5 on: 11-January-19, 15:35:32 »
It is an official MSI vbios update so of course warranty will be fine.
AMD Ryzen 9 3900X
Windows 10 Pro
furkan_reisoglu
« Reply #6 on: 13-June-19, 11:22:47 »
Hey there my S/N is 602-V373-113sb1903006486 can I get a Vbios update also I don't know how to update it soo a quick tip would be appreciated if there is any trick to it. If its just an installation then I'll do it :D
  • 微星科技
« Reply #7 on: 13-June-19, 11:29:41 »
Please open an own thread and there also provide your current vbios saved to file else we can't check if there is an update.
GOP / UEFI Vbios requests - Read Here First
:floblock:
AMD Ryzen 9 3900X
Windows 10 Pro
