Author Topic: Vbios - MSI RTX 2080 Gaming X TRIO  (Read 239 times)
MickelmoreTopic starter
« on: 11-January-19, 08:11:42 »
Hello!
I see many updates the vbios of their cards even though they don't have any issues, is it good to updates the vbios?
And are there any details of what has been changed in the different versions? :)
My serial is : 602-V372-40SB1810012953
Thanks in advance.
- Mickelmore
  • 微星科技
Re: Vbios - MSI RTX 2080 Gaming X TRIO
« Reply #1 on: 11-January-19, 10:46:55 »
You have the latest vbios already (NV372MH.105) so there is no update anyway.
It is not necessary to update when you don't have an issue. On the other hand you will also not run into already fixed issues at a later point if at the latest bios already. It is your own decision.
No, changelogs for vbios aren't public.
Core i7 7820X @ 4302.24 MHz (43 * 100.05 MHz, fixed all cores), 1.126v - delidded and using der8auer Skylake-X Direct Die Frame
MSI GeForce RTX 2080 GAMING X TRIO --> MSI GeForce GTX 1080 Ti GAMING 11G
Windows 10 Pro
MSI MAG BUNKER
« Reply #2 on: 14-January-19, 01:25:54 »
Okay, awesome! :)
And only way to see if there is a new vbios is to ask in here? :)
  • 微星科技
« Reply #3 on: 14-January-19, 11:02:05 »
:hat tip:
Either ask here or use Live Update.
Windows 10 Pro
MSI MAG BUNKER
