Author Topic: 470x gaming plus new build wont power off after shutdown  (Read 113 times)
zoltair.gamerTopic starter
Hi there!
Just finished new my new ryzen 2700x system build using the x470 gaming plus motherboard.  Build went well and all parts worked out of the box.  One quirk I have is the pc will not power off after windows shuts down.  Monitor turns off but even after 5+ minutes all LED's are on and I'm seeing intermittent drive activity (case has a hd activity light)  All driver and windows updates have been run.  I appreciate any ideas and my specs are below:
Ryzen 2700x
x470 gamin gplus mainboard
16gb corsair vengence 3000mhz ram dual channel
samsung 970 evo 500gb nvme boot drive
1tb western digital games ssd
4 tb spinning hd (toshiba 7200 rpm)
evga g3 supernova 750w PSU
evga geforce RTX2070
Fractal Define R6 case (not that it matters)
thanks again :)
rbleroy91
  • LIEUTENANT GENERAL
  • RBL_FR
Re: 470x gaming plus new build wont power off after shutdown
« Reply #1 on: 11-January-19, 17:56:38 »
1/ Do a clear CMOS:
- Power off PSU, unplug the power cord and wait that all mobo's leds light off.
- Either
    . short JBAT1 during at least 20s
      (if you have not a jumper cap, use something like a screwdriver but be cautious to touch only the 2 pins of JBAT1) or
    . remove the battery cell during 30mn.
- Plug the power cord and power on.
- You would see a message.
  Enter in bios setup, press <F6>, confirm,
  set "SETTINGS \ Advanced \ Windows OS Configuration \ Windows 10 WHQL Support" = "Enabled",
  press <F10>, confirm. The pc should reboot.
2/ If previous did not resolve, disable Windows 10 Fast Startup:
- Enter in "Control Panel \ Power Options".
- Click "Choose what the power buttons do", then "Change settings that are currently unavailables".
- Search for "Turn on fast startup (recommended)" entry.
  . If you have it, uncheck.
  . If you have not,
    . enter in "Settings > Accounts > Sign-in options".
    . set "Use my sign-in info to automatically finish setting up my device and reopen my apps after an update or restart" at "Off".
- Restart then shutdown.
3/ If previous did not resolve, how do you shutdown pc?
Hoping it shall help,
:hat tip:
MSI X99A XPower Gaming Titanium (Bios 1.61)  –  Windows 7-10 Pro x64 (1809)  –  i7-6850K + BeQuiet! Dark Rock Pro 3 + Corsair Vengeance LPX Series DDR4 3466MHz 4x16Go + MSI GeForce GTX 1070 Gaming X 8G + SSD Samsung, 1x 850 PRO 512GB (SATA) [Boot+OS drive] & 1x 970 PRO 1TB (NVMe) + HD SATAIII Seagate Barracuda, 7x 1TB & 1x 3TB + LG BR R/W + BeQuiet! Dark Power Pro 11 1000W 80PLUS Platinum +  BeQuiet! Dark Base Pro 900 + HyperX Alloy Elite keyboard + HyperX Pulsefire FPS mouse
« Reply #2 on: 12-January-19, 09:58:29 »
seams to have cleared up on its own.  normal shutdown/power off last night and tis morning.  :)
rbleroy91
  • RBL_FR
« Reply #3 on: 12-January-19, 10:09:14 »
Good news, happy for you! :pompom:
Have a good day,
:hat tip:
mattia
  • CORPORAL
« Reply #4 on: 12-January-19, 10:16:13 »
So you have done nothing to fix it?
