Author Topic: MSI MAG27CQ Developper Window (Maybe?)  (Read 463 times)
SpuhTopic starter
« on: 11-January-19, 13:52:29 »
Hello Everyone,
I recently bought this monitor and was fumbling around with all the options in the menu.
At some point I must have activated something. Whenever I power up my Monitor I get a window in the top left corner.
I did some googling, but couldnt find any thread or video resembling this occurance.
A picture should be in the attachments.
With the button on the backside of the screen, I can easily dismiss this window.
I would like to know how to prevent this window from popping up, since I dont feel like dismissing this everytime I use my Monitor.
Hopefully this information is sufficient to come up with the answer.
Thanks in advance,
David
Yang
  • AIO Moderator
Re: MSI MAG27CQ Developper Window (Maybe?)
« Reply #1 on: 13-January-19, 20:11:46 »
1.Please choose to exit on this blue screen.
2.Please refer manual for doing reset it once on OSD.
https://www.msi.com/monitor/support/Optix-MAG27CQ
tolga.akbas24
« Reply #2 on: 07-April-19, 12:56:26 »
Hello, sorry for making this post live again. But if i wanted to bring that menu again what should i do ? because i may need burning settings for future. Thanks.
Yang
  • AIO Moderator
« Reply #3 on: 19-April-19, 02:54:29 »
Step 1:Keep pressing menu key at back side and then power on monitor at the same time
Step 2: Pressing menu key at back side and it will OSD menu.
OSD menu appeared "F" on upper left corner on OSD menu.
Step3: Please choose to "F" and then will be showed it again.
tolga.akbas24
« Reply #4 on: 19-April-19, 03:15:19 »
Step 1:Keep pressing menu key at back side and then power on monitor at the same time Step 2: Pressing menu key at back side and it will OSD menu. OSD menu appeared "F" on upper left corner on OSD menu. Step3: Please choose to "F" and then will be showed it again.
Sorry to bother you again but im getting confused at first step. when i press menu button on the back it only power up screen, it doesnt change anything even if i keep holding it while screen is powering up, the "F" isnt showing up.
Could you please tell me in details how to do it ?
