Author Topic: CPU Bottleneck?  (Read 239 times)
stlmikeyTopic starter
CPU Bottleneck?
« on: 11-January-19, 19:28:15 »
So I just swap out my msi 2080 gaming x trio for 2080 ti msi gaming x trio
shadow of tomb my frames increase from 42 to 54 @ 4k.
loaded up bfv for this first time without rtx on i had trouble hitting 60 frames @ 4k
I didn't had windows update installed to test with rtx on.
my cpu is i5 8400 gen8 with 16gigs of ram.
RTX On
http://tinypic.com/view.php?pic=214y3vn&s=9#.XDktJ1xKguU
RTX OFF
http://tinypic.com/view.php?pic=rbksb4&s=9#.XDktHFxKguU
darkhawk
Re: CPU Bottleneck?
« Reply #1 on: 12-January-19, 07:47:09 »
It's a problem with the game. Just do a quick search for battlefield 5 bottleneck and you'll see tons of info about it.
System 3MSI Z390 GodlikeIntel i9 9900K32GB DDR4 @ 3600 MHz MSI RTX 2070 Gaming Z 8GB
Re: CPU Bottleneck?
« Reply #2 on: 12-January-19, 11:52:17 »
So do you think it is my cpu having issues keeping up with the game?
Any other games I should check to make sure its not problem with the card itself?
Thanks
darkhawk
Re: CPU Bottleneck?
« Reply #3 on: 12-January-19, 13:44:55 »
Thanks
I didn't say that at all.....
I just said that there's a problem with the game, Battlefield 5. It's not an issue with the CPU or the GPU.
