Author Topic: Bios updates  (Read 495 times)
paulo_sousa_21Topic starter
Bios updates
« on: 12-January-19, 01:54:14 »
Hello, so i already updated my graphics card bios and i'm wondering if after this update i did to the gpu bios if i should i expect more updates to this bios or this is just one and final update?
Thanks in advance.
  • 微星科技
Re: Bios updates
« Reply #1 on: 12-January-19, 06:45:17 »
:confused2: and what graphics card do you have and what vbios did you update??? Add S/N and a copy of the current vbios saved to file.
AMD Ryzen 9 3900X
Windows 10 Pro
Re: Bios updates
« Reply #2 on: 12-January-19, 11:47:33 »
Yes i'm sorry i forgot to post that.
Msi GTX1050ti 4GB OC Edition
S/N: 602-V809-783SD1702137632
Thanks in advance
  • 微星科技
Re: Bios updates
« Reply #3 on: 12-January-19, 13:15:23 »
AMD Ryzen 9 3900X
Windows 10 Pro
Re: Bios updates
« Reply #4 on: 13-January-19, 12:06:06 »
i'm sorry again here you have it.
  • 微星科技
Re: Bios updates
« Reply #5 on: 13-January-19, 14:08:54 »
You are using vbios version NV809MH0.7M0. It is the latest and final. Nothing newer is to be expected.
AMD Ryzen 9 3900X
Windows 10 Pro
