Author Topic: PCI-e SSD upgrade.  (Read 319 times)
lexie_1Topic starter
  • SERGEANT
PCI-e SSD upgrade.
« on: 12-January-19, 09:45:36 »
I own a GL62M7REX with a128 GB PCI-E Gen3 SSD inside.
I want to upgrade to 256 GB.
How can this be done?  I don't want to loose my current data and I want to do this myself.
And how to clone 2 drives if i have only 1 PCE-E slot availible in the Laptop.
Please advise what i should buy and what tool i need to Clone the SSD.
Regards,
Alex
AMD Phenom II X4 940 Black 3.0GHz HT 8MB AM2 Box
Corsair 2x2GB DDR2 SDRAM PC8500 CL5.0 DHX Dom.
Logitech MX400 Laser Mouse
Microsoft Comfort Curve Keyboard 2000 Retail (zwart)
nVidia GeForce 8800 GTS 320MB
MSI DKA790GX Platinum
Sweex Card Reader CR005V2
Corsair Powersupply CMPSU-650TXEU 650W
Trust  Ultra Small Bluetooth 2.1, 25m
Cooler master Centurion 5
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
Re: PCI-e SSD upgrade.
« Reply #1 on: 12-January-19, 12:32:22 »
You have 4 choices.
1) Buy an M.2 USB 3.1 caddy/enclosure and clone it yourself.
2) Buy a 2.5" M.2 SATA caddy and clone from the internal bay.
3) Clean install W10.
4) Have a computer shop do the cloning and install for you.
Cloning software is available from the SSD manufacturer website.
You will have a 128GB M.2 leftover, I would suggest the USB 3.1 M.2 caddy, you will be able to use it as a portable storage device. You also have the need for cloning and it serves a purpose there as well. You can, as well, keep the M.2 with the OS on it for at least 1 year until the warranty on the notebook runs out. Some warranty providers will insist that the notebook be in OEM condition for service work, you would have to swap them out.
https://www.google.com/search?
q=USB+3.1+M.2+caddy&num=50&source=lnms&tbm=isch&sa=X&ved=0ahUKEwidqbHo7ejfAhWqHTQIHaVbBZkQ_AUIDigB&biw=1396&bih=720
https://www.google.com/search?q=2.5%22+M.2+SATA+caddy&num=50&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjq4eHC7-jfAhX0ITQIHd6tAFcQ_AUIDigB&biw=1396&bih=720
W10 allows you change the default storage location of all your stuff to any drive.
If you store nothing on your C drive and put all your stuff on D, W10 should not need more than 80GB space.
It might be better to buy a 1 or 2TB 2.5" SATA SSD for storage, and leave the OS on the 128GB M.2 SSD.
https://www.newegg.com/Product/ProductList.aspx?Description=2tb%20ssd&Submit=ENE
In Canada Call MSI @ 1-888-447-6564
Mon-Fri 5:00AM-4:00AM PST (Weekend and Holiday closed)
Note: RMA, Customer Service, Technical Support
Global 1-800 listings https://www.msi.com/page/hot-line
  • SERGEANT
« Reply #2 on: 15-January-19, 00:41:28 »
Thanks for the clear explanation.
