Author Topic: B450 gaming pro carbon motherboard not loading BIOS?  (Read 284 times)
jon.ibrahim23Topic starter
Hello I just recently built my computer,
Computer spec.
Ryzen5 2600x
RX590
1TB HDD
256GB SSD
B450 GAMING PRO CARBON MOTHERBOARD
EVGA 750BQ
 So my story is when I try to get into BIOS the only thing that is being shown is MSI CLICK BIOS 5 then under that it shows GAME BOOST and next to that it shows A-JUMP also CPU SPEED, DDR SPEED, and BOOT PRIORITY which is empty. I also tried F11 to get to boot screen but its only showing MSI logo and nothing loads. I'am able to get into windows 10 and everything else seems to be working properly. I would just like to get into BIOS so I can adjust some settings if any one can help guide me let me know. Thank you.
plutomate
  • MAJOR GENERAL
Re: B450 gaming pro carbon motherboard not loading BIOS?
« Reply #1 on: 13-January-19, 21:44:41 »
are you using tv as monitor? did you try use regular desktop monitor? can you show us a screenshot?
« Reply #2 on: 13-January-19, 22:09:02 »
Forgot to mention 16gb 3000mhz of Ram 2 8gb sticks.
And yes I'm using a TV as monitor HDMI port. Dont currently have a PC monitor to try 🙁
plutomate
  • MAJOR GENERAL
it's not a new issue here on the forum and 99% people fix it by using a regular monitor to change BIOS settings first then connect back to tv.
plutomate
  • MAJOR GENERAL
just come across this thread, you can take a look
https://forum-en.msi.com/index.php?topic=313879.0
« Reply #5 on: 14-January-19, 06:06:06 »
Thank you for the quick response. Looks like I'll be purchasing a monitor with display ports. I'll keep you posted if I'm still running into the same issue
