Author Topic: Mystic Light and Gaming App not working  (Read 121 times)
ebrahim4tuinTopic starter
« on: 28-January-19, 14:32:55 »
Hopefully someone here can help me with this issue.
I recently got myself an RGB MSI graphics card(GTX 1080TI LIGHTNING Z) and i have tried both the MSI gaming app and Mystic light. Both of them give me an error saying "The platform does not support this application"
As far as i know, platform generally refers to the OS (?). I have Windows 10 pro 64bit Version 1809 OS BUILD 17763.253.
Additionally I have tried the MSI Command Center and this application gives me the error of "Command Center does not support this Motherboard!". I am running an Asus ROG STRIX z370-h gaming.
Could all the applications possible be failing to run because of the motherboard?
I have tried many different versions of the Gaming app and Mystic Light (2 and 3) and am absolutely stumped by this.
If anyone has any experience or advice on this it would be highly appreciated.
  • 微星科技
Re: Mystic Light and Gaming App not working
« Reply #1 on: 28-January-19, 14:37:29 »
Are you using the LN2 vbios?
Core i7 7820X @ 4203.84 MHz (42 * 100.09 MHz, fixed all cores), 1.086v - delidded and using der8auer Skylake-X Direct Die Frame
MSI GeForce RTX 2080 GAMING X TRIO
Windows 10 Pro
MSI MAG BUNKER
« Reply #2 on: 10-February-19, 22:43:12 »
Hey, I do not think that I am. I have not done anything to modify it.
  • 微星科技
« Reply #3 on: 11-February-19, 12:21:57 »
Save the current vbios to file and add it.
Windows 10 Pro
MSI MAG BUNKER
