Author Topic: MSI Optix MAG241C Freesync, gsync compatible?  (Read 6283 times)
axellmalinaoTopic starter
« on: 30-January-19, 17:49:31 »
[font=Verdana, Tahoma, "Nimbus Sans L", arial, sans-serif]I just bought MSI Optix MAG241C 24" Freesync to pair up with my MSI Ventus RTX 2060, MSI said that it's GSYNC compatible but I am experiencing some flickers while gaming[/font][/color]
Im using Displayport
https://www.pcgamer.com/msi-claims-these-16-freesync-monitors-are-g-sync-compatible/
Yang
  • AIO Moderator
Re: MSI Optix MAG241C Freesync, gsync compatible?
« Reply #1 on: 30-January-19, 20:24:13 »
MAG241C is support FreeSync.
It should be use on G-Sync compatible but not proved by NVIDIA.
So cannot 100% guarantee.
MAG241C is not on NVIDIA list.
https://www.nvidia.com/en-us/geforce/news/g-sync-ces-2019-announcements/
victormld
« Reply #2 on: 31-January-19, 06:01:00 »
Hey,
I have a MAC241C monitor and have performed several tests to verify the G-Sync compatibility.
Using the Nvidia controller is possible to activate the G-Sync and use it. However, some issues can be highlighted.
During the pendulum test is possible to see some flickering (is like the screen is increasing and decreasing the brightness fastly). This flickering happens when the FPS goes below 48, i. e., outside of the Freesync range of the monitor that ranges from 48 Hz to 144 Hz.
Also, in the Assassins Creed Odyssey, I have noted this behavior again, but now FPS game is inside of the monitor Freesync range. In the menu of abilities, the flickering is strongly noted when I move the cursor over the abilities.
In CS:GO the flickering also happens sometimes, but it is rare.
About this problem, it is possible MSI provide some fix? Something like automatically changing from G-Sync to V-Sync when the FPS goes below the monitor Freesync range?
PS: My video card is an MSI RTX 2070 ARMOR 8G.
Yang
  • AIO Moderator
« Reply #3 on: 31-January-19, 18:57:02 »
For flickering: please modify soem setiting on OSD for checking.
Game mode: User
Response time: Normal
Anti Motion Blur: OFF
FreeSync: OFF
Pro Mode: User
HDCR: OFF
https://www.msi.com/monitor/support/Optix-MAG241C#down-manual
For G-Sync:
MAG241C is not OFFICIAL support G-Sync.
