Author Topic: ethernet doesn't have a valid ip configuration  (Read 381 times)
d0ta_zoldicTopic starter
« on: 03-February-19, 05:57:29 »
please help me, as im not an expert but i have a little knowledge on computers.
i have already tried all the possible turnaround to fix the issue but no LUCK.
all the instructions are being followed but no luck
https://windowsreport.com/ethernet-valid-ip-configuration-windows-10/
MOBO A320M PRO-VD/S
had updated bios for AMD athlon ryzen3 compatibility.
darkhawk
Re: ethernet doesn't have a valid ip configuration
« Reply #1 on: 03-February-19, 10:15:44 »
I mean....you really need to be more specific. Just giving some generalized idea of what the issue is, isn't going to help us at all to try and give you support.
See : >>Posting Guide<<
System 3MSI Z390 GodlikeIntel i9 9900K32GB DDR4 @ 3600 MHz MSI RTX 2070 Gaming Z 8GB
