Author Topic: Anthem and BF5 with RTX 2080ti purchase  (Read 178 times)
asfameniTopic starter
  • PRIVATE E-1
« on: 06-February-19, 22:48:12 »
So just picked up a Duke 2080ti (Fantastic GPU btw), registered it and wanted to get the Anthem and BF5 code to redeem, got this message instead: Due to an overwhelming response to this promotion and a larger-than-expected amount of claims, the active code is unavailable. Once again thank you for taking part in this promotion.
Really? I know its a GPU being purchased but seriously they should always honour promotions like this, anyone got any info about this or is it worth even contacting MSI directly?
Cheers
  • 微星科技
Re: Anthem and BF5 with RTX 2080ti purchase
« Reply #1 on: 07-February-19, 12:45:37 »
Core i7 7820X @ 4203.84 MHz (42 * 100.09 MHz, fixed all cores), 1.086v - delidded and using der8auer Skylake-X Direct Die Frame
MSI GeForce RTX 2080 GAMING X TRIO
Windows 10 Pro
MSI MAG BUNKER
darkhawk
« Reply #2 on: 07-February-19, 21:36:07 »
There is nothing anyone here on the forums can do to help you.
You'll need to contact MSI directly, as flobelix suggests.
ServerMSI X370 SLI PlusAMD Ryzen 5 1500X16GB DDR4NVidia Quadro 4000
System 3MSI Z390 GodlikeIntel i9 9900K16GB DDR4 @ 3600 MHz MSI GTX 1070Ti Armor OC
System 4MZI Z390 Gaming Pro Carbon ACIntel i5 860016GB DDR4 @ 3600 MHzMSI 7700 Aero
  • PRIVATE E-1
« Reply #3 on: 08-February-19, 02:22:47 »
Thanks guys I just mostly wanted to see if anyone else had run into this and tried to contact MSI directly about it. Already did submit a ticket a couple of days ago but if its just a case of "Sorry we somehow ran out of digital keys" (and someone on the forum knows it) then I wouldn't bother looking into it any further.
Cheers
  • PRIVATE E-1
« Reply #4 on: 13-February-19, 15:31:52 »
fwiw if anyone else was having this issue you should try to re-apply for the codes now, it looks like the message I received first up was because of Chinese New Year holiday not actually because they had ended the promotion, I re-applied after the holiday and within 2 days had both codes working fine. Cheers and GL
