Author Topic: MSI 2070 Armor Coil Whine  (Read 151 times)
bmwilson2014Topic starter
« on: 09-February-19, 10:12:10 »
I've recently built a new PC with a MSI 2070 armor as my GPU- During games and character selection screens (in WoW and Divinity 2), I have noticed a pretty high sounding coil whine, especially when FPS is >100. For example, if i framelock my FPS to around 60 in these games, the sound goes completely away. I have tried enabling V-Sync in both games, but still does not have any effect on sound unless I lock my frames to 60 fps. This is a problem for me, due to the fact I have a 144hz monitor and would prefer to be able to get high frames w/o such an annoying sound. I do have "adaptive fresh" on in the nvidia panel. Can anyone help me with these, any other suggestions or should I consider returning card? *The sound does increase bit by bit when raising the fps frame cap*
  • T9246ED, Бивша комета
  • Administrator
Re: MSI 2070 Armor Coil Whine
« Reply #1 on: 10-February-19, 05:54:47 »
try a different PSU
often such appear when there is bad combo between the PSU and the card
hudson161
« Reply #2 on: 11-February-19, 09:33:59 »
I have coil whine from my MSI RTX 2070, PSU replacement didnt fix it, coil whine is only during heavy load, the worst whine is when I have extremely high fps like in games menus.
  • Administrator
« Reply #3 on: 11-February-19, 13:15:52 »
undervolting GPU would helps to reduce it
hudson161
« Reply #4 on: 11-February-19, 14:54:01 »
I will try, but if I lower voltage, I would not be able to overclock or can I
  • Administrator
« Reply #5 on: 12-February-19, 09:13:12 »
should be still able to do it
hudson161
« Reply #6 on: 13-February-19, 09:09:29 »
It didnt help anyway, going to return it
