Author Topic: z390 Pro Carbon AC I/O shield RGB light not working  (Read 197 times)
HaroFTopic starter
« on: 09-February-19, 18:01:08 »
I have a Z390 Pro Carbon AC mother board and the I/O shield lighting is not working.  The Mystic Light Software recognizes the board and the I/O shield lighting and the different components (mother board type, lighting, graphic card, different lighting options, etc...) but the I/O shield will not light at all. The lighting strip on the side does work correctly though.  I have updated the MB Bios and Firmware using the dragon center app and still the I/O shield will not light.  does anyone have a possible solution to this or is the lighting most likely just defective? The mother board works fine otherwise.
LBJistherealchamp
  • MAJOR
Re: z390 Pro Carbon AC I/O shield RGB light not working
« Reply #1 on: 12-February-19, 03:10:26 »
Is the RGB cable of I/O shield properly and firmly connected to the JPIPE being located above the first PCIE slot on the motherboard?
Try unplugging it and putting back in.
ayeshenmarianen
« Reply #2 on: 15-August-19, 02:57:32 »
Hi there, im having the same problem, i disconnected and reconnected it but it still wont light up. what does the jpipe actually do ?
Nichrome
Errors are red, My screen is blue .I think I deleted, System32
