Author Topic: GP72M 7REX Leopard-Pro - Problem with the screen  (Read 274 times)
pgiannaTopic starter
« on: 11-February-19, 03:42:20 »
I have a problem with the screen of a GP72M laptop. I get horizontal lines at the top of the screen. It starts happening a minute or so after I boot and over time it gets worse. I tried re-installing drivers but it didn't help. Any idea for what else I could try before sending it for repair?
RaiderGamer
  • LIEUTENANT COLONEL
  • Online Online
Re: GP72M 7REX Leopard-Pro - Problem with the screen
« Reply #1 on: 11-February-19, 13:20:10 »
just throwing out a few thoughts:
https://www.msi.com/Laptop/support/GP72M-7REX-Leopard-Pro
update bios and ec firmware
reinstall windows clean with latest drivers
see if loosing the bezel helps.
remove bezel and re-seat your screen connector
order a superior screen (120hz 3ms) and install it yourself using youtube assembly guides for a nice upgrade
gk2377
  • CAPTAIN
« Reply #2 on: 15-February-19, 02:39:40 »
not sure if you posted your question here to have official reply regarding this issue?
simply check this out!
https://register.msi.com/service/ocss
whitecat8890
  • SECOND LIEUTENANT
« Reply #3 on: 15-February-19, 02:49:26 »
I think you'd better update the BIOS.
It seems like a BIOS issue.
pennknig
  • Online Online
« Reply #4 on: 16-February-19, 13:14:39 »
Defective panel, repair/warranty time.
