Author Topic: GF72-8RD cooling  (Read 100 times)
flakpanzerTopic starter
GF72-8RD cooling
« on: 11-February-19, 07:17:58 »
I'd like to know what you are all using as external cooling for the GF72-8RD laptops. For me, i am still using its built in fan only, but im planning to get a laptop cooler so as too reduce the 'pull' needed by the fans to suck in the air from underneath.
I also add a spacer underneath to ensure the air gets easily into the bottom vents. Once i get the new cooler i will try to see if its possible to add filters to the cooler to prevent the laptop itself from getting dust inside.
