Author Topic: How to convert the 7.1/5.1 output from MSI H310M PRO-VD to optical  (Read 84 times)
kmbhaugTopic starter
I have a surround sound headset that needs optical input.
Just got a new pc with an H310M PRO-VD mobo. Been trying to figure out how to convert the sound output to optical.
I bought a SPDIF bracket: https://www.ebay.com/bhp/spdif-bracket
But during installation I realized this mobo does not have the spdif out pins...
So I somehow need to convert the output from the existing audio out ports to optical. Any ideas on how I could do this?
Does the HDMI out also carry the 7.1/5.1 sound, or only the video? In the manual it is not covered. If it has the 7.1/5.1 sound I can buy a HDMI to optical converter so that would be great.
Or is it possible to do this with a USB to Optical converter? I tried got one, and it succeeded in converting the USB to 5.1 analog output.  But it was not able to create 5.1 optical output. Could be the device I bought...
Or does anyone know of any other usable converters or ways of achieving this?
Thanks in advance for any help!
HenryW
You would need to buy a sound card that has S/PDIF output
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
Thanks HenryW, it dawned on me too that a soundcard would fix this. I was just hoping for a simpler and cheaper option. But I have soon wasted the same amount of money a soundcard costs on non-working solutions so might as well just get one.
