Author Topic: Mystic Light - Corsair Light Enhancement Kit  (Read 77 times)
banana999Topic starter
  • CORPORAL
« on: 11-February-19, 15:07:21 »
Hi there, is there any way to control this from Mystic Light? https://www.corsair.com/gb/en/Categories/Products/Accessories-|-Parts/PC-Components/Memory/CORSAIR-VENGEANCE-RGB-PRO-Light-Enhancement-Kit/p/CMWLEKIT2
They are only lighting modules without any actual memory. The real memory is controlled fine through Mystic Light but it does not detect these lighting modules. I have contacted Corsair and they have told me that they are both controlled the same way with the same firmware so it should work with Mystic Light too but may need an update.
Thanks.
plutomate
  • COLONEL
Re: Mystic Light - Corsair Light Enhancement Kit
« Reply #1 on: 12-February-19, 04:31:37 »
Can you provide your full system config? like which MB, which RAM + enhancement kit, mystic light version etc
darkhawk
« Reply #2 on: 12-February-19, 08:20:41 »
It should work just fine. They're just memory sticks with RGB, but no memory on them. I don't see a reason they wouldn't work.
ServerMSI X370 SLI PlusAMD Ryzen 5 1500X16GB DDR4NVidia Quadro 4000
System 3MSI Z390 GodlikeIntel i9 9900K16GB DDR4 @ 3600 MHz MSI GTX 1070Ti Armor OC
System 4MZI Z390 Gaming Pro Carbon ACIntel i5 860016GB DDR4 @ 3600 MHzMSI 7700 Aero
  • CORPORAL
« Reply #3 on: 12-February-19, 13:56:18 »
Motherboard: MSI Z390 Gaming Pro Carbon AC, BIOS 7B17v13
RAM: Corsair Vengeance RGB Pro 2x8GB DDR4 3200MHz https://www.corsair.com/uk/en/Categories/Products/Memory/Vengeance-PRO-RGB-Black/p/CMW16GX4M2C3200C16
Lighting Kit: Corsair Vengeance RGB Pro Light Enhancement Kit https://www.corsair.com/uk/en/Categories/Products/Accessories-|-Parts/PC-Components/Memory/CORSAIR-VENGEANCE-RGB-PRO-Light-Enhancement-Kit/p/CMWLEKIT2
Mystic Light: Version 3.0.0.46
Windows 10 Pro, 1809
They can be controlled through iCue fine so they do work. Just did not get detected by Mystic Light so I had to install iCue. I have tried re-installing Mystic Light with / without iCue etc.
