Author Topic: [BIOS Request] RX470 Armor 4GB OC  (Read 126 times)
SagaraSTopic starter
« on: 12-February-19, 01:04:16 »
One of my co-workers decided to order a GPU from eBay. I'm assuming it was used for mining as the GPU is throwing up Code 43's in device manager and the AMD installation says the GPU is not detected. The serial number on the card is, S/N: 602-V341-49SB1611003763. The seller also shipped the GPU in what appears to be a non-original box (Same model), as the S/N does not match the sticker on the GPU. The S/N on the box is, S/N: 602-V341-49SB1611003800.
Attached is also the original BIOS (113-MSITV341MH.2M0), anything other than whatever was on the card bricks the GPU and will not post.
  • T9246ED, Бивша комета
  • Administrator
Re: [BIOS Request] RX470 Armor 4GB OC
« Reply #1 on: 12-February-19, 09:17:58 »
here is the latest version .2M2
