Author Topic: GTX 1050 not recognized by application on MSI GF63-8RC Laptop  (Read 172 times)
mattTopic starter
I have a brand new MSI GF63-8RC Laptop with a dedicated Nvidia GTX 1050 GPU. I am trying to use an AR glasses called Meta2 with an accompanying Unity SDK, but the application keeps crashing. I noticed that the application that comes with Meta is not recognizing the GPU and is only using the integrated display on the mother board to render. I suspect it doesn't recognize the device ID on my GPU. I tried updating and downgrading the drivers, and I found that only Nvidia drivers from MSI driver download site will work, whereas the drivers downloaded from Nvidia website will prompt an error that says Couldn't find compatible hardware.
Here are the hardware IDs from my GTX 1050:
PCI\VEN_10DE&DEV_1C92&SUBSYS_123C1462&REV_A1
PCI\VEN_10DE&DEV_1C92&CC_030200
Driver version: 24.21.13.9921
Compatible IDs:
PCI\VEN_10DE&DEV_1C92&REV_A1
PCI\VEN_10DE&CC_030200
PCI\VEN_10DE
PCI\CC_030200
PCI\CC_0302
Is there any way I can use my GTX 1050 on this application without changing anything from the application? Is it possible to change the device ID to something that the application could potentially recognize? Or are there other ways to make the application work?
Thanks!
Amaella
  • MAJOR
  • Online Online
Re: GTX 1050 not recognized by application on MSI GF63-8RC Laptop
« Reply #1 on: 12-February-19, 02:51:38 »
Open up nvidia control panel, there should be a way to add the app to the list which uses nvidia gpu. Not sure where exactly as I haven't had an optimus laptop for about 2 or 3 years now... But you should be able to find it somewhere.
Previous laptops: Asus K55VJ (i5-3210m, gt635m, 12GB ddr3 RAM, Samsung EVO 850 500GB)
                          MSI GT72VR 6RE (i7-6820HK, gtx1070), MSI GT75 8RG (i7-8750H, gtx 1080)
Current desktops:  i7-8700k, evga 1080ti ftw3, Asus Z370 prime-a, 2x8GB Corsair RAM @3000MHz, Fractal Design Define r6 TG white, Noctua NH-D15
                          i7-7740x, msi x299 raider, msi gtx 1060 armor 6GB, 2x8GB RAM, NZXT h440
If my answers help you out, feel free to help me out by marking them as best solution! Happy gaming to all!
mattTopic starter
« Reply #2 on: 12-February-19, 03:44:09 »
I have tried that, but it doesn't work, the application is still crashing. thanks for the reply though, any other thoughts?
