Author Topic: BIOS for Armor RX570 4GB  (Read 227 times)
9sashablack9Topic starter
« on: 12-February-19, 03:24:52 »
Raleon RX570 Armor 4GB OC
S/N1: 602-V341-121SB1703000188
CHK:298
Bought a used. Sorry just need the stock one
for flashing to its original state.
  • 微星科技
Re: BIOS for Armor RX570 4GB
« Reply #1 on: 12-February-19, 11:38:16 »
The latest original vbios is TV341MH.571, it is attached.
For flashing ATIWinflash in Windows. Should explain itself.
Note that you need to rename the vbios file to .rom for flashing after unpacking.
MSI X299 Gaming M7 ACK (MS-7A90) Bios 1.A0
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #2 on: 13-February-19, 00:45:53 »
Thank you very much.
  • 微星科技
« Reply #3 on: 13-February-19, 12:39:52 »
:hat tip:
Windows 10 Pro
MSI MAG BUNKER Case
