Author Topic: Used RX 480 Armor with no display signal  (Read 210 times)
dmta30Topic starter
« on: 12-February-19, 09:29:13 »
I recently got an ex-mining RX 480 Armor OC 8GB, but when I went to test it in my system with a B350 Tomahawk, I get no signal to my monitor via HDMI or DVI. I currently use an RX 480 Gaming X 8GB, which works fine in the same system, and I've tested an XFX RX 480 GTR 8GB running fine as well. It shouldn't be a software issue since these are all the same GPU. I tried both PCIe slots as well.
When I tested the Armor OC in another system with an ASRock B450 Pro4, I get a display signal via HDMI, so the card technically works, just not with my system.
The only thing I can say is that it seems to be an issue related to my B350 Tomahawk. Any ideas for how to solve this?
  • 微星科技
Re: Used RX 480 Armor with no display signal
« Reply #1 on: 12-February-19, 11:44:28 »
Add the card's S/N and a copy of the current vbios saved to file.
Core i7 7820X @ 4302.99 MHz (43 * 100.07 MHz, fixed all cores), 1.124v - delidded and using der8auer Skylake-X Direct Die Frame
32GB (4 x 8GB) Corsair CMR32GX4M4Z3200C16 @ 1601 MHz (DDR4-3200), 16-18-18-36-2t, 1.35v
MSI GeForce RTX 2080 Ti GAMING X TRIO
Windows 10 Pro
MSI MAG BUNKER
dmta30Topic starter
« Reply #2 on: 15-February-19, 18:25:47 »
Sorry for the wait.
S/N: 602-V341-22SB1610001497
Device manager gives code 43 for the card, but I could get the bios.
  • 微星科技
« Reply #3 on: 16-February-19, 14:11:59 »
The latest original vbios for your card is TV341MH.1K2. Try it: https://forum-en.msi.com/index.php?topic=312970.msg1793981#msg1793981
Windows 10 Pro
MSI MAG BUNKER
dmta30Topic starter
« Reply #4 on: 16-February-19, 18:32:55 »
So I flashed the bios and tried booting up the system. I get basic display out, but my motherboard tells me that:
There is no GOP (Graphics Output Protocol) support detected in this card. 'Windows 8.1/10 feature' settings in BIOS will be changed to 'Disabled'.
  • 微星科技
« Reply #5 on: 17-February-19, 07:40:50 »
It is a UEFI vbios, problem is with your board then.
Windows 10 Pro
MSI MAG BUNKER
dmta30Topic starter
« Reply #6 on: 09-March-19, 18:03:03 »
I talked to the seller and they linked me to this vbios:
https://www.techpowerup.com/vgabios/196214/MSI.RX480.8192.170727.rom
I flashed it to my card and it works perfectly now.
  • 微星科技
« Reply #7 on: 09-March-19, 18:05:31 »
You flashed the card with a wrong vbios. Warranty is now void...
Windows 10 Pro
MSI MAG BUNKER
