Author Topic: MSI z77a-g41 (bios2.13)GPU not working by  (Read 447 times)
y650318Topic starter
« on: 13-February-19, 08:03:56 »
now i cant use my rx580 the only card that works now is my gtx750ti for some reason
  • 微星科技
Re: MSI z77a-g41 (bios2.13)GPU not working by
« Reply #1 on: 13-February-19, 13:00:30 »
Add full system specs -> >>Posting Guide<<
Have you tried any other card than the RX 580 or the GTX 750Ti? Is the RX580 known working (tested in another pc)? What exact RX580 is it?
AMD Ryzen 9 3900X
Windows 10 Pro
« Reply #2 on: 13-February-19, 22:44:02 »
Cpu:i5 2500k
Mainboard:Z77A-G41(2.13)
GPU:Powercolor AXRX 580 8GBD5-3DHDV2/OC
PSU:Cooler Master G550M
  • 微星科技
« Reply #3 on: 14-February-19, 13:01:05 »
AMD Ryzen 9 3900X
Windows 10 Pro
« Reply #4 on: 16-February-19, 00:04:42 »
Specs :
CPU: Intel Core i5-2500K Motherboard: MSI Z77A-G41 RAM: 8GB Dual-Channel DDR3 1600MHz (10-10-10-30) PSU: Cooler Master G550M
RX580 can work PC won'startAnything I can do ?
我試圖重置CMOS 並沒有改進
  • 微星科技
« Reply #5 on: 16-February-19, 14:15:13 »
:think:  what? Have you tested the RX 580 in another pc?
我試圖重置CMOS 並沒有改進
:think:  Post in English only.
AMD Ryzen 9 3900X
Windows 10 Pro
