Author Topic: RTX 2080 TI Duke OC boost clock issue  (Read 548 times)
thicoTopic starter
« on: 13-February-19, 13:58:15 »
I have a 2080 TI Duke OC card, already since november. When I just got it, I had issues with the card never going above 1350 mhz clock speed. I decided to upgrade all my other hardware.
I have a Z390 Ace MB with an i9 9900k now.
The card worked fine for about a month now, but I just updated my nvidia drivers to 418.91 and the issue is there again. No matter how much I try to tax the gpu (superposition benchmark, battlefield V), the clock speed never goes above 1350 mhz.
I was wondering if maybe it could be something vbios related?
I have put my current system info from gpuz and current vbios in attachment.
Serial number : S/N 602-V371-08SB1809000730
Any help would be greatly appreciated.
  • 微星科技
Re: RTX 2080 TI Duke OC boost clock issue
« Reply #1 on: 13-February-19, 14:21:46 »
At least there is an update so you can try. You have version NV371MH.111 while latest is NV371MH.113.
For flashing use nvflash: https://www.techpowerup.com/download/nvidia-nvflash/
note that you need to rename the unpacked file NV371MH.113 to .rom (e.g. 113.rom) for flashing.
If you saved the nvflash for windows .exe say under drive d: you can start it in a Windows prompt in administrator mode after you saved the .rom at the same place. First type d: (or wherever you saved nvflash and the .rom) and press enter. Now you changed to drive d: where you have nvflash in the root directory. Now start the flash with the following line: nvflash -6 113.rom (press enter)
Note that if using a 64bit OS you'll need to run the line nvflash64 -6 113.rom
Windows 10 Pro
MSI MAG BUNKER Case
thicoTopic starter
« Reply #2 on: 13-February-19, 14:47:52 »
Just updated the vbios, unfortunately no difference.
Maybe any other suggestions?
  • 微星科技
« Reply #3 on: 13-February-19, 15:43:02 »
Check the power management settings in the driver. If it is at Prefer Maximum Performance change to Optimal or vice versa. Also remove any manually set oc.
If still no help remove the current driver in safemode using >>DDU<<. After a reboot install the driver you used before and that worked.
Windows 10 Pro
MSI MAG BUNKER Case
thicoTopic starter
« Reply #4 on: 14-February-19, 11:22:14 »
No luck. :sad:
So, I used DDU to reinstall the previous driver, which was 417.35 with the same result. Using DDU again to install the latest driver also doesn't work.
Any other ideas? I am afraid about sending the card back to the retailer because it does seem to work occasionally, like it did for me the past month although it didn't work correctly before.
  • 微星科技
« Reply #5 on: 14-February-19, 12:47:31 »
Reinstalling drivers wasn't all I suggested:
Windows 10 Pro
MSI MAG BUNKER Case
thicoTopic starter
« Reply #6 on: 14-February-19, 13:30:25 »
You're right. I never did any custom overclocking. I don't have any software like afterburner or precision x installed on my pc.
I just tried toggling between the 3 available power management settings in the nvidia control panel (adaptive, optimal power and maximum performance) neither of which make any difference.
I can see in gpu-z that the clock speed never goes below 1350 with maximum performance, but never above either.
  • 微星科技
« Reply #7 on: 14-February-19, 14:11:56 »
It seems to be a common issue seen on some 2080Tis (no matter the make or model) and Titan RTX
In most cases card is to be returned. As latest vbios didn't help and there was no change with driver I'd probably give clearing mainboard cmos (>>Clear CMOS Guide<<) and/or updating mainboard bios a shot and then rma if no luck.
Windows 10 Pro
MSI MAG BUNKER Case
thicoTopic starter
« Reply #8 on: 14-February-19, 14:41:24 »
I tried first with clearing CMOS and after with updating the bios, which did not fix the issue.
So, I guess the best thing will be to RMA it. Would it be better for me to handle this directly with MSI or through store from which I bought it?
I very much appreciated your help, even though we were not able to fix the issue.
  • 微星科技
« Reply #9 on: 15-February-19, 11:18:47 »
:hat tip: sorry we couldn't solve the issue.
As you are from Europe you can only rma to the store. There is no direct rma in Europe.
Windows 10 Pro
MSI MAG BUNKER Case
