Author Topic: Stock BIOS for MSI RX 570 Gaming X 4GB  (Read 1302 times)
mullanssonTopic starter
« on: 21-February-19, 09:55:27 »
Does anyone know where I could find stock BIOS for an MSI RX 570 Gaming X 4GB?
S/N: 602-V341-530B1709000705
Bought it used and get the code 43 error so I assume it may be flashed.
  • 微星科技
Re: Stock BIOS for MSI RX 570 Gaming X 4GB
« Reply #1 on: 21-February-19, 13:36:08 »
The latest original vbios for this card is TV341MH.533: https://forum-en.msi.com/index.php?topic=297296.msg1675328#msg1675328
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #2 on: 21-February-19, 15:24:28 »
Thanks!
Looking in GPU-Z and ATI Flash, could you tell whether my current BIOS is stock or not? I see that the name is that older version mentioned in the other thread, but I guess that is no guarantee that it is stock BIOS right? Looks like the attached images.
  • 微星科技
« Reply #3 on: 23-February-19, 05:16:26 »
Version TV341MH.531 is an original vbios. Can't tell if it had been modded or not with these screenshots though.
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #4 on: 23-February-19, 06:37:35 »
Ok, assumed that. Thanks anyway.
Will go ahead and flash it then to see if it solves the code 43 problem.
« Reply #5 on: 23-February-19, 13:05:47 »
It worked, card is running perfectly now! Thanks again.
  • 微星科技
« Reply #6 on: 23-February-19, 18:30:52 »
:hat tip:
Windows 10 Pro
MSI MAG BUNKER Case
sanggamsiburian
« Reply #7 on: 24-February-19, 03:15:35 »
{HELP}
i have MSI RX570 4G GamingX Samsung, is it ok if i use this vbios for my gpu?
if you had better suggestion it would be great :)
i'm sorry for my bad English :)
  • 微星科技
« Reply #8 on: 24-February-19, 05:05:23 »
Stick to your own thread and don't hijack other threads. >>Please read and comply with the Forum Rules.<<
Windows 10 Pro
MSI MAG BUNKER Case
