Pages: [1] 2 3  All   Go Down
Author Topic: 2080TI Lightning Z going to safe mode/1350MHZ when stock cooler fans removed  (Read 7655 times)
etiennelerouxTopic starter
I created an account just to post my problem here.
I just installed the new bitspower waterblock on my lightning Z.
It took me many hours to realize that the GPU goes to safe mode (stuck at 1350 MHZ) when the stock fans are not plugged in...
I tried both bioses, even the new LN2 bios... doesn't work.
To make it work, I had to remove the fans from the stock cooler and plug them in the PCB while having the waterblock on.
It's quite ridiculous...
It's a card built for LN2 overclocking... of course A LOT of people are gonna remove the stock cooler.
MSI can you please fix this quickly with a new vbios?
Thanks
  • 微星科技
this is a forum so if you want to address MSI about it and make sure they take care of your case you will need to contact MSI directly: >>How to contact MSI.<<
Anyway we will also notee our contacts about it to see if it is a general problem. PLease also add S/N and a copy of the current vbios saved to file.
AMD Ryzen 9 3900X
Windows 10 Pro
  • 微星科技
MSI tested the issue and could not copy this behavior with LN2 or normal vbios. Even with fans disconnected there is no 1350MHz limit. Vbios engineers also confirmed that no safe mode function is included to limit boost clock without fan signal.
Might be that temp or power limit is reached and causes the issue. What temp is the gpu at under load?
Also you could try driver version 418.81 that had been used by MSI for testing: https://www.geforce.com/drivers/results/142225
AMD Ryzen 9 3900X
Windows 10 Pro
Temps are in the low 40s... Another guy on overclock.net had the same issue as me and the problem resolved when he puts back the fans. I swear it has something to do with the fans, I tested it twice!
xspeed69
  • CORPORAL
The limit is there for sure, me and many others have this issue.
Maybe MSI didn't test it properly. If you just unplug fans the card might work ok but then if you switch bios or flash or whatever, then safe mode kicks in.
Quote from another person:
"I have verified thru extensive testing by myself and some other engineers that during a bios flashing, The checksum engages and checks all jumpers and headers on the card for any voltage spikes,drops or dead voltage issues, aka if theres no fan plugged into the header, the checksum reports back to the flasher and by default rolls back and sets and locks card to its default profile....."
For me safe mode kicks in if:
- I switch bios from normal to ln2 or the other way around.
- Flash bios/update
- power off complete, etc take power cords off or remove card from system.
I have tested this on Intel Z370 and Z390 platform with totally different components and issue is same on both systems.
Of course it's possible we all have bad cards, that wouldn't be surprising at this point.
  • 微星科技
I will ask them to test again to test the situations you listed.
AMD Ryzen 9 3900X
Windows 10 Pro
Yes please keep us updated. It's an annoying bug.
Slovak_killer
Can confirm, its happening on my Lightning Z also.
Everytime you either :
a) Flash/change bios
b) unplug gpu or whole system
c) reinstall nvidia drivers
d) somehow change any value directly related to gpu
 with fans unplugged card goes to safe mode (1350mhz core). Card is not usable on watercooling because of this bug, I am assuming its some protection directly written to card because flashing different bioses from other vendors doesnt help.
Please investigate this issue with MSI as its unacceptable that you have to use fans dummies to even run your card on watercooling.
  • 微星科技
We will see what they say.
AMD Ryzen 9 3900X
Windows 10 Pro
  • 微星科技
Ok, issue got confirmed by MSI. They found the following workaround so far, please test it.
1. Connect FAN to the pin header
2. Install the RTX 2080 Ti Lightning Z in the system
3. Re-install NV driver  (the version used by MSI is 419.35)
4. Power off the system
5. Take the RTX 2080 Ti Lightning Z out of the system and disconnect FAN
6. Install the RTX 2080 Ti Lightning Z in the system
7. Power on the system and do not re-install NV driver
AMD Ryzen 9 3900X
Windows 10 Pro
Slovak_killer
Is that joke ? i paid 1500€ for gpu which when i put on water i can never update/reinstal drivers LOL ? and thats no workaround ive been doin that everytime when ive switched bios or uplugged PC. Please let MSI know that we need some software update not that crap.
  • 微星科技
It is a "workaround"... Of course they are working on another solution. You can also contact MSI yourself: >>How to contact MSI.<<
AMD Ryzen 9 3900X
Windows 10 Pro
Flobelix, can you confirm they are working on a new vbios to fix this issue?
xspeed69
  • CORPORAL
But can this be fixed with just a new bios? I have tested different bioses from other companies with this card and issue is the same.
Maybe there is something really wrong on the PCB itself?
  • 微星科技
MSI could copy the issue. What they do/can do is up to MSI. If you want to know from MSI: >>How to contact MSI.<<
AMD Ryzen 9 3900X
Windows 10 Pro
mrkingx11
did anybody contact MSi ? what did they say ?
xspeed69
  • CORPORAL
I'm hoping flobelix can keep us up to date.
mrkingx11
i bet they pushed it to next week
amazing how a 1600$ gpu is useless when a waterblock is installed
xspeed69
  • CORPORAL
If they can fix it by simple bios update then great!
But for some reason I'm fearing there is a bigger issue on the card...
  • 微星科技
Dear all,
MSI provided a modified beta vbios for testing. It will disable any RGB working though. If you want to still try it send me a personal message and I will provide a link via personal message.
AMD Ryzen 9 3900X
Windows 10 Pro
mrkingx11
  • 微星科技
AMD Ryzen 9 3900X
Windows 10 Pro
xspeed69
  • CORPORAL
Reading from other forums it seems this new vbios solves fan problem, that's great!
Not going to test it on my card just yet because you lose additional voltage controls that ln2 bios originally offers.
Hopefully another version is pushed out quickly :)
mrkingx11
i hope there's an official bios coming out soon to take full advantage of this gpu
  • 微星科技
I asked MSI for a full LN2 vbios which is now available via pm request. RGB is still disabled with this beta vbios.
AMD Ryzen 9 3900X
Windows 10 Pro
mrkingx11
what about the normal Bios ? RGB doesn't matter i want the voltage sliders
  • 微星科技
:think: might be useful to test the LN2 vbios.
AMD Ryzen 9 3900X
Windows 10 Pro
I sent you a PM for this beta vbios. Thanks!
  • 微星科技
AMD Ryzen 9 3900X
Windows 10 Pro
christian.leitgeb
Hello! I would also need the new beta bios for the 2080Ti Lightning Z please! :-)
Many thanks!
  • 微星科技
AMD Ryzen 9 3900X
Windows 10 Pro
mrkingx11
so the LN2 bios didn't fix the issue i was talking about which is the memory voltage sliders
i wonder if MSi is ever going to fix this , if not i won't wait long to sell the card and get a 2080ti Matrix
  • 微星科技
I asked MSI for looking into this specific issue if it can be duplicated. Still promoting other brands' products will not be tolerated here so please don't do that again.
AMD Ryzen 9 3900X
Windows 10 Pro
mrkingx11
just saying that it's unacceptable how we are running a beta bios because the fans got disconnected
  • 微星科技
AMD Ryzen 9 3900X
Windows 10 Pro
  • 微星科技
MSI replied that memory voltage control is not supported for the RTX 2080 Ti Lightning. Memory voltage control not being implemented therefor has nothing to do with the vbios fix but is meant to not be available due to a hardware limitation.
They will consider to implement it again in further designs.
AMD Ryzen 9 3900X
Windows 10 Pro
mrkingx11
do they know it was there when the fans were connected ?!
  • 微星科技
It might have been a glitch. According to vbios engineer it should not work. However I can ask again.
AMD Ryzen 9 3900X
Windows 10 Pro
czesiek779
  • CORPORAL
I would like the unlocked VBIOS a go.
Any chance MSI can provide the uncorked VBIOS with working RGB?
xspeed69
  • CORPORAL
So these settings are shown by mistake?
  • 微星科技
Check pm
So far not, we'll see.
AMD Ryzen 9 3900X
Windows 10 Pro
xspeed69
  • CORPORAL
You ever gonna get tired spamming that link? You get no help from there.
  • 微星科技
No, because if wanting to contact MSi that is the only way. I can only report what MSi tells me. If you are not happy with it I can't do anything about it.
AMD Ryzen 9 3900X
Windows 10 Pro
xspeed69
  • CORPORAL
So any update on bios or voltage adjustments?
  • 微星科技
I would have updated the thread if there would be.
AMD Ryzen 9 3900X
Windows 10 Pro
daddybeargame
Hi,now we have vbios with disabled safe mod,but dont have on it power limit 120% as base LN2?and no OC settings?
can u give me link for latest version vbios wich disable safe mod without standrt fans?
  • 微星科技
AMD Ryzen 9 3900X
Windows 10 Pro
daddybeargame
nice support from MSI.u pay 1700 usd for card.it doesnt work with watercolling-no response from MSI support,no response from this forum.great.
  • 微星科技
This is a forum. Nobody is here for your 24h support but when he/she is around and has time/can help.... check pm.
AMD Ryzen 9 3900X
Windows 10 Pro
daddybeargame
i think,that if urs card for such price dont work-u too will be mad.
Pages: [1] 2 3  All   Go Up
