Author Topic: P55-CD53 MOBO  (Read 930 times)
msantell1Topic starter
P55-CD53 MOBO
« on: 07-April-19, 19:56:13 »
MSI Motherboard - P55-CD53.
 Dimm 2 is not showing up in BIos.   I am looking for 2 - 8GB Ram to use in Dimm 1 and Dimm 3, does anyone have the part number for such part or is it even available?
Thank You
Mike
  • 微星科技
Re: P55-CD53 MOBO
« Reply #1 on: 08-April-19, 13:54:21 »
:think: You are looking for a memory kit or the reason for your problem with DIMM2?
Windows 10 Pro
MSI MAG BUNKER Case
Re: P55-CD53 MOBO
« Reply #2 on: 08-April-19, 20:45:00 »
Memory kit would be great,  but if I can find out why Dimm 2 is not working that would be great as well.
  • 微星科技
Re: P55-CD53 MOBO
« Reply #3 on: 09-April-19, 13:37:07 »
Does no stick work in DIMM2? If so reseat the cpu and check the socket for bent pins.
Windows 10 Pro
MSI MAG BUNKER Case
Re: P55-CD53 MOBO
« Reply #4 on: 09-April-19, 20:38:19 »
Correct, no memory stick will work in Dimm 2.  When I install memory in Dimm 2 and Dimm 4 nothing on screen. When I put memory in Dimm 1 and Dimm 3 the PC works but it's only 4GB total Ram. I am looking for 2-8GB DDR3 Memory.
As for resetting the CPU, I am not sure how that is done.
HenryW
Re: P55-CD53 MOBO
« Reply #5 on: 09-April-19, 21:55:37 »
Remove the CPU cooler and then the CPU then check the CPU socket for bent pins. The problem you are having is usually caused by bent pins or improperly seated CPU. If you can post a good picture of the socket.
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
Re: P55-CD53 MOBO
« Reply #6 on: 10-April-19, 19:15:43 »
Everything was working fine until I removed the XMS3 Memory and installed the
Kingston HyperX FURY 8GB Kit (2x4GB) 1600MHz DDR3 CL10 DIMM - Red (HX316C10FRK2/8).  That's when all the problems started.
  • 微星科技
Re: P55-CD53 MOBO
« Reply #7 on: 11-April-19, 12:21:15 »
And have you checked the socket?
Windows 10 Pro
MSI MAG BUNKER Case
Re: P55-CD53 MOBO
« Reply #8 on: 11-April-19, 13:46:44 »
So we found out what the culprit is.  After checking the memory , the motherboard is bad.  I am able to use 3 sticks of ram in Dimm 1,3,4 but when trying ram in Dimm 2, there is no post beep or video on screen.
As for checking the CPU, I am not sure what to look for.  And, we noticed a burn mark on the video card.  :nooo:
  • 微星科技
Re: P55-CD53 MOBO
« Reply #9 on: 11-April-19, 13:48:28 »
You should not check the cpu but the cpu socket on the board for bent pins.
Windows 10 Pro
MSI MAG BUNKER Case
Re: P55-CD53 MOBO
« Reply #10 on: 11-April-19, 14:35:49 »
How would I check for that?   And if there are bent pins, how do I bend them back?
  • 微星科技
Re: P55-CD53 MOBO
« Reply #11 on: 11-April-19, 14:39:54 »
With a bright light and a magnifying glass. If pins can be bend back depends on the amount of bent pins. If just few are bent you can try with a needle.
Windows 10 Pro
MSI MAG BUNKER Case
Re: P55-CD53 MOBO
« Reply #12 on: 11-April-19, 14:42:35 »
So I would need to shut down the PC, remove the Heatsink Fan and CPU?   I don't have any thermal paste laying around.
  • 微星科技
Re: P55-CD53 MOBO
« Reply #13 on: 11-April-19, 15:05:39 »
Yes, of course.
Then you will need to get some.
Windows 10 Pro
MSI MAG BUNKER Case
Re: P55-CD53 MOBO
« Reply #14 on: 11-April-19, 15:17:22 »
Ok, Thanks flobelix
  • 微星科技
Re: P55-CD53 MOBO
« Reply #15 on: 12-April-19, 10:57:21 »
:hat tip:
Windows 10 Pro
MSI MAG BUNKER Case
Re: P55-CD53 MOBO
« Reply #16 on: 27-April-19, 17:06:04 »
All pins are good on CPU socket and CPU,  Now what?
  • 微星科技
Re: P55-CD53 MOBO
« Reply #17 on: 27-April-19, 18:17:38 »
Most likely the board uses a Foxconn socket that is oknown for ram issues. It appears to be a hrdware issue in any case.
Windows 10 Pro
MSI MAG BUNKER Case
Re: P55-CD53 MOBO
« Reply #18 on: 27-April-19, 19:23:39 »
So it's off to the junkyard.
